So with the price of BBply at $45 a sheet now.. What's a good material to use and maybe paint for backers. I always just used BBply as it wasn't overly expensive but I'm sure there is a cheaper alternative. I like a backer to be glued so it gives added strength and not too thick of material so it can still fit in most standard framed.. I guess it really wouldn't have to be glued but would need to be able to be painted.. I have a tractor portrait to do for a friend and hoping to maybe paint the backer the correct tractor color. I haven't done portrait work for several years now.. so almost like I'm relearning, LOL..
 There is a product called Sureply that's used for underlayment, a bit cheaper @29.00 1/4x4x8. I had some left over from our kitchen remodel and used it a backer, it took stain quite nice. The manufacturer recommends you score it with a knife and snap it. The interior make-up is hard on blades so if cutting with a table saw I would use an older blade.
For portraits I won't use anything but 1/4" BB ply I get online in the precut 12" x 24" size.  I did note the price jumped significantly the last time I ordered it..
I believe, a well done cutting deserves to be mounted on a substaintial permanent backer that I can feel confident won't deteriate over the near or far term.  Especially so, as my backers are often painted a solid color using rattle can spray paint, stained and/or hand painted with Artist Acrylics.   To me the backer is as important part of a portrait as is the cut panel.
The total thickness of the glued-up 5/32" solid core ply and the 1/4" thick BB ply backer is just a tad over 3/8" and works well for mounting in a 1/4" x 1/2" deep rabbet I cut in my 3/4" thick Poplar Frames.
I used to use the colored foam type sheets.. I just don't really like it anymore after using something much stronger and more solid. Most my recent backers was 1/4" walnut plywood for sign type projects and clocks.. but for something going to be framed I feel like I need to use thinner than 1/4" Thinking 1/8" would for much better in a frame.
