1 hour ago, Rolf said:
I created this Beveled inlay guidelines chart for myself.
I would still do a test cut
Thanks Rolf. That will save a lot of time and create a great start point. Experimentation still a necessity but this will save headaches.
Another thing to consider when cutting inlays is the direction in which you cut. Because of the angle of the cut, a very sharp (pointed) turn can try and force the blade to cut across itself. I don't think I am explaining this very well, but if you set the blade at an angle and try and cut a sharp point in one direction, then the other, you will see what I mean.
8 hours ago, Rolf said:
Take your time when cutting inlays and make sure not to push sideways.
These were 1/4 into 1/4 inch material. Olson 2/0 R 28 TPI
Very nice Rolf.
I have a dozen of each of these type of hinges, circular and rectangle. Have had them in a box for years, just never got around to using them.
13 hours ago, timelett said:
Beautiful work is this a pattern?
The designs were something I created from clipart.  The box designs are John A. Nelson with some modifications by me.
I bought the hinges from https://www.nationalartcraft.com/product-index.asp  I don't think the rectangular ones are available any more.
I stopped making them as they wasted a lot of wood.  Having said that, I still have some of the hinges and should use them up.
This was my collection.
This is an interesting question and discussion.  Rolf's graph is helpful.  I do have a question about the graph.  I think the width of the kerf is the important variable rather than the blade thickness. I have tried measuring the kerf and found it always to be a bit more than the blade.
I measured kerf by taking a piece of wood about 2" long, cutting in two and remeasuring  it.
For anyone with a calculator----
I think that the angle equals the inverse sin of the kerf divided by board thickness.
Edited by Sycamore67
Thanks for that info. Unfortunately, 63 years have passed since the last time I used that sort of math so I'll just have to take your word for it. Lol.
Edited by OCtoolguy
That is why you need to do test cuts. Since different blades have different tooth offsets.  Also the quality and adjustments of a saw also impact the kerf.
