Since Ray  @OCtoolguy showed his mistake and a graceful recovery  I decided to show my ooops.
I want advice on #2 please.
I am building just another hat. Black walnut.
Ooops.
1)  big hole was a bit too big for the crown. I miss marked which line to go with.
Recovery: add another ring to the crown (bowl).  This made the hat taller.
Fix procedures:  Think.
2)  As I was sanding the outside of  the bowl the glued pieces cracked at the thin spot where the drill hole is.
Recovery:  So I put super glue on the inside.  This helped fix the crack but will look bad.
See the "added" bottom ring  is not sanded yet.
20220403_154300.thumb.jpg.1efa8d9c7b4c6c2661b7835023beeffd.jpg20220328_154417.thumb.jpg.2110c8d937604e0aa68b69b4e624cb89.jpg
Fix procedures..
   A) dont have drill holes line up. stager drill hole.
   B) Don't sand outer bowl until  bottom is glued on. In my case the top.
Please , I would like opinions.
The hat is not done yet... but here is a fit check of brim to crown.  The crack is in the back.
Me. Mark
Edited by preprius
