nrscroller Posted April 16, 2022 Report Share Posted April 16, 2022 (edited) Hi all, I thought I might try an Alex Fox pattern, anyone know what he puts his patterns on and then just sticks it on the wood? I wonder if it is full size shipping labels or what, it's something that peels off. Thanks Bill Edited April 16, 2022 by nrscroller OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Dan Posted April 16, 2022 Report Share Posted April 16, 2022 At one time he was just spraying adhesive on the wood then attaching the pattern. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
preprius Posted April 17, 2022 Report Share Posted April 17, 2022 (edited) i asked that question to myself everytime i see his videos. I thought about that twice today while i was in garage. I hope is safe. Me. Edited April 17, 2022 by preprius OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Dan Posted April 17, 2022 Report Share Posted April 17, 2022 I stand corrected. On this video he is using self-adhesive, full-page labels. I hope this solves the mystery. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
NC Scroller Posted April 17, 2022 Report Share Posted April 17, 2022 I have made many Alex projects. I attach mine just like any pattern I attach to the wood and that is by spraying with 3M Supper 77 on the back of the pattern. Dan and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
Roberta Moreton Posted April 17, 2022 Report Share Posted April 17, 2022 The self adhesive full page labels I use are permanent. They do NOT peal off. I put them on top of shelf liner. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Blaughn Posted April 17, 2022 Report Share Posted April 17, 2022 (edited) I HATE lifting patterns! I tried something different with my current project: As has been suggested several times: Sand the top surface of the work piece with 220 grit sand paper to prep it for applying the pattern. Wipe the surface after sanding with a cloth dampened with alcohol. When the alcohol was thoroughly evaporated (2-3 minutes) I applied the Walmart "Duck" clear shelf lining plastic. At this point I did an additional step that really helped: I used a rubber wallpaper seam roller to press the Duck shelf lining plastic into the surface of the wood piece. You can actually see the shelf liner becoming more clear as the adhesive is pressed into the wood. I print my patterns on 8.5 x 11 Press-ply labels Using these I apply the pattern to the Duck shelf liner. Finally I cover the Press-Apply label with 2" clear package tape. This has drastically reduced the tendency to lift and, for me, is now my routine. Wallpaper seam roller: https://smile.amazon.com/Xtozon-Deadener-Filter-Application-Rolling/dp/B07DQG4LCJ/ref=sr_1_3?crid=160RQWEU0JLR8&keywords=wallpaper%2Bseam%2Broller%2Brubber&qid=1650223235&sprefix=wallpaper%2Bseam%2Broller%2Caps%2C104&sr=8-3&th=1 Press-ply Labels: https://smile.amazon.com/Pres-ply-Address-Labels-30605/dp/B0006HV9HU/ref=sr_1_2?crid=B8ES9OTIR0WW&keywords=8.5+x+11+press-ply+labels&qid=1650224061&sprefix=8.5+x+11+press-ply+labels%2Caps%2C88&sr=8-2 Edited April 17, 2022 by Blaughn Quote Link to comment Share on other sites More sharing options...
Ctutor Posted April 17, 2022 Report Share Posted April 17, 2022 Avery makes a removable label sheet for inkjet or laser. Check amazon Quote Link to comment Share on other sites More sharing options...
dgman Posted April 17, 2022 Report Share Posted April 17, 2022 (edited) Scroll Saw pattern supply catalogs sell a full sheet with pull off backing that is designed for applying to wood projects. You print directly to the sheet, then peel off the backing and apply to your wood blank. The sheets are supposed to be easily removable. Wooden Teddy bear and Cherry Tree sell them. Edited April 17, 2022 by dgman John B, Dan and Gene Howe 1 2 Quote Link to comment Share on other sites More sharing options...
