Ray, your work always amazes me.. the quality of products many folks do on here and the uniqueness of some of the projects. A lot of folks say they envy the people that can do what they like for a living and I am thankful to be able to do that but at the same time I envy those that can take on and create unique projects. Dave Monk with his inlay work is another that I like to see. I wish you all would post more of your works and some of the process to get those beautiful results.
4 hours ago, Paladin said:
Those look great.  I remember seeing this pattern somewhere, but can't recall - who is it by?  On the top rings, are you using a router to make the recess for the other piece to fit into?
Yes, a 3/8" rabbet 1/4" deep.
2 hours ago, barb.j.enders said:
very nice work.
Have you considered using a jig to hold the pieces together instead of taping & retaping.  Steve Good has a pattern for a jig on his site.  Might speed things up a bit.
Thanks Barb. I've tried using the clamp but it just didn't work out. Maybe I'll give it another try or figure out a better clamp. One of the 2 long cuts on the side either starts or ends in such a way that the clamp side is in the way. Maybe a small relief cutout on the clamp wall would help. Now you have me thinking. Thanks. My brain gets fogged often so I need folks like you to blow away the haze. Lol.
  • 2 weeks later...
Update! I have now completed all the cutting and it's on to the sanding, assembly and finish. This represents about 40 hours so far. I can't do more than 2 of the sides at a time or my eyes fall out onto my cheeks. Very intensive up close cutting. I used a combination of # 1, 3, 5 Pegas MGT blades for all of it.
18 minutes ago, preprius said:
Wow 40 hours so far. At $20hr ...
10 hours per candle holder.
The friends gotta be very good one. I hope they appriciate your work.
I like your work.  ..  hint hint .
Come over. I also give lessons.
