Excelent job on the Three Amigos!.  Very nice cutting and colloring work. Ya did good!!!
Yes painting the backer is time consuming and can be difficult to get the right colors in the right place with out overlaps or missed areas.  I have gone to making paper stencils from the cutting pattern to get most of the colors in the correct place. Helps but not always 100% accurate.
Not intended as a critism but I'll offer one suggestion.  In the future try cutting nominal 1/8" thk  material and use 1/4 as a backer.  There is less visable vertical cut edges.  Also, the 1/4" thk backer makes the panel much more rigid.
Thanks for the advice Frank, it makes sense-don't know why I didn't think of that
8 hours ago, Dave Monk said:
Very nice and colorful. What color stain did you use on the frame?
Used Behr B3550 Fishing Village-I think it would have looked better if I had used Alder that wasn't so spalted. I am working on a frame using aspen and think the stain will look better on the lighter wood.
I think you did a splendid job on this. Colorizing it from the backerboard to show through in all the right places can be a real challenge alright. Especially when some of the lines are very small and close to something that has to be a different color. It all looks so nice and you should be proud to hang this one on the front room wall for others to admire when they visit you.
Dick
heppnerguy
