danny Posted May 13, 2022 Report Posted May 13, 2022 Did I see Alex Fox use Contact Cement for Securing a Project? Think I did. I watched his Video making the little Doggie or Kitty key chain holder. Any How.... Does anyone use this method? He makes it look so Easy.... Pros n Cons Please....Thanks Danny :+} OCtoolguy 1 Quote
Dave Monk Posted May 13, 2022 Report Posted May 13, 2022 2 hours ago, danny said: Did I see Alex Fox use Contact Cement for Securing a Project? Think I did. I watched his Video making the little Doggie or Kitty key chain holder. Any How.... Does anyone use this method? He makes it look so Easy.... Pros n Cons Please....Thanks Danny :+} I haven't used that but I have been using spray glue which is really easy. . lawson56 and OCtoolguy 2 Quote
WayneMahler Posted May 13, 2022 Report Posted May 13, 2022 I have been using 3m 77 with out issues. Have to check out his video. lawson56 and OCtoolguy 2 Quote
John B Posted May 14, 2022 Report Posted May 14, 2022 Using contact cement to join pieces of timber etc, just goes so far against the grain, (Pun intended). Each to their own, but contact cement is not designed for that. It is perfect for laminating, fixing thin sheet materials etc, anywhere you can apply a heavy downward pressure to ensure a good bond. there are a thousand better products for timber to timber joints. danny, OCtoolguy, Norm Fengstad and 2 others 3 2 Quote
Wichman Posted May 14, 2022 Report Posted May 14, 2022 5 hours ago, danny said: Did I see Alex Fox use Contact Cement for Securing a Project? Think I did. I watched his Video making the little Doggie or Kitty key chain holder. Any How.... Does anyone use this method? He makes it look so Easy.... Pros n Cons Please....Thanks Danny :+} From the comments section, the horses mouth: Thanks, glue - it is called "88" of Ukrainian production, instruction: apply glue on both surfaces, wait about 10-15 minutes until the glue dries, squeeze the glued surfaces. I am not sure that you will find it in your country, one of my customers wrote that in the USA similar glue is called "Contact Cement". Also I know that many of my customers use "Gorilla" wood glue. lawson56, OCtoolguy and danny 3 Quote
danny Posted May 14, 2022 Author Report Posted May 14, 2022 Thanks to All that replied and Especially to "WICHMAN". Just to clear the air I have Always used the Super Glue products for this type of securing wood to wood. I have used Contact Cement in the past and THOUGHT hey if this is the way with some I will give it a try, but Now not sure about it. Thanks Again John B and OCtoolguy 2 Quote
