Often times when I first log in I will see files listed in the Random Files section which I would like to look at.
After the log in, however, the random files have changed so I cannot just click on the thumb-nail but, when I
enter the caption under the file I saw previously, it is not found in the search engine.
Is there a simple way to go to a certain page to look for the items which were previously seen in the Random
Files?
Thanks for any assistance.
God Bless! Spirithorse
Hmmmm....The first thing I'd do is when you log in, check the "Log Me On Automatically Each Visit," that way you don't have to fuss with the login each time you visit SSV (assuming you're not on a shared computer).
What you could do is open another window, then login. After you are logged in, go back to your main window and click the link. That might work for ya.
If its a pattern, you can usually guess where the pattern is located by category in the Pattern Library. If its a different pic, you could note the author, then look for their album.
Thanks, Travis,
I'll try that open another window trick.
The last one I looked for was a project captioned ragim666 (if memory serves me correctly) and no matter what combination of
those letters or numbers I tried, nothing at all came up and I didn't see a member remotely similar to that caption.
To be honest, I don't even recall what the project was but, it was a completed project someone did and I just wanted to look
at more than the thumb-nail.
