I did that guy, too.  Depending on the wood you used, a rustic frame would look good.  I'd used a piece of scrap 1/2" plywood, so I just put a couple of eye-screws in the top and ran some hemp twine through to hang it on the wall.
Unless the cutting is constructed as a Plaque, It is my opinion, all portrait type panels that will hang in an environment other that a shop, need an aprropriate Frame,
That well done Wolf cutting would look great on an oversized backer about a inch larger than the cut panel all around in a nice rustic/distresssed Frame having rails about 1 3/4 wide.
Edited by FrankEV
  I believe a frame adds a lot to a piece. I don't, however, think a separate picture type frame is always necessarily.  Some pieces are great with just a backer board extended a 1/2 inch all the way around and painted or stained works quite well. It is a matter of preference. I also believe a pattern without any frame or extended backer board is not usually a very good idea as it needs some kind of contrast. The exception might be something that has a lot of fret work and itself can stand alone, sometimes.
Dick
heppnerguy
I'd just put a backer on it and round off the corners personally.
I've done several different ways with a piece.   A backer ½" bigger all round, full frame, just rounding the corners. All look good in my opinion and I've never had a complaint about whichever way.
I have to agree with Frank.
A live edged - grayed out frame would really set that guy apart!  Fantastic cutting job.
