Popular Post Eplfan2011 Posted August 11, 2022 Popular Post Report Posted August 11, 2022 Well I put my parts on my saw this morning and decided to try it out. I wanted to try something simple as this was my first time using a scroll saw. Knocked up this pattern in inkspace with a font I liked taped it up and went at it! Next time I'll make the outline in grey and thinner as the blade was hard to see in the black. I mostly kept to the line (but they are only a suggestion right) but the s has a few flatspots on it ( I'm presuming I'm turning without feeding?) Kind of embarrassing after seeing what you guys turn out but realize we all have to start somewhere. Thanks for all the positive input on my posts so far ( I know the new guy can be anoying ) and any constructive criticism is appreciated if it's going to improve my work, it needs it Thanks for looking ! new2woodwrk, stoney, CSull and 16 others 19 Quote
Ctutor Posted August 11, 2022 Report Posted August 11, 2022 My 89 year young eyes also find it hard sometimes to see lines. I put a light down on the side of the table so it shines across the work piece. By moving the light I can make a sharp shadow on the line at the saw point that tends to highlight the blade. Works real good on a 2.0 blade that is small to be gin with. Your work is nothing to hide ;looks great!. Norm Fengstad, Juan Rodriguez, OCtoolguy and 1 other 4 Quote
Denny Knappen Posted August 11, 2022 Report Posted August 11, 2022 For the first, looks real good. A suggestion, keep your first project in your shop and watch your progress as you scroll through life. lawson56, OCtoolguy, Greatgrandpawrichard and 2 others 5 Quote
Eplfan2011 Posted August 11, 2022 Author Report Posted August 11, 2022 9 minutes ago, Denny Knappen said: For the first, looks real good. A suggestion, keep your first project in your shop and watch your progress as you scroll through life. Thanks Denny ... will do! OCtoolguy and Greatgrandpawrichard 2 Quote
Dak0ta52 Posted August 11, 2022 Report Posted August 11, 2022 I see nothing wrong with your first cut. In fact, I think it is pretty darn good! If you are familiar with Inkscape, I might suggest putting the cut lines in red and your pattern fill in a light gray. I set my stroke (lines) at .009 of an inch and try to split the line when I'm cutting. If you drift off the line, don't try to jump back onto the line quickly. Gradually work your way back toward the line. As Darryl (Ctutor) said, a light also helps. I have a lighted magnifier that makes the lines look huge and makes them much easier to follow. When I sometimes look around the magnifier straight at the pattern, I think to myself, darn those are really thin lines. Keep up the good work. You'll be jumping on some major fretwork very soon. Wichman, OCtoolguy, heppnerguy and 1 other 4 Quote
Oldmansbike Posted August 11, 2022 Report Posted August 11, 2022 Looks great to me. A lot better than my first cutting OCtoolguy, Eplfan2011, Greatgrandpawrichard and 1 other 4 Quote
Sycamore67 Posted August 11, 2022 Report Posted August 11, 2022 Looks good especially for a first try. Greatgrandpawrichard, OCtoolguy and heppnerguy 3 Quote
Freddie Posted August 11, 2022 Report Posted August 11, 2022 Looks great to me. I started using red lines to help with shadows and tracking the blade. I have started using a magnifier as well, but sometimes it actually makes my vision worse if I get the focal length off. What type blade did you use? Thanks in advance OCtoolguy and Greatgrandpawrichard 2 Quote
OCtoolguy Posted August 11, 2022 Report Posted August 11, 2022 1 hour ago, Eplfan2011 said: Thanks Denny ... will do! Be sure to date it too. Look back a year from now. You'll be pleasantly surprised. I wish I had done as well on my first cut. Great job. Greatgrandpawrichard 1 Quote
Scrappile Posted August 11, 2022 Report Posted August 11, 2022 Nothing wrong with that cutting. Did you enjoy doing it? If so you are well on you way. Eplfan2011, heppnerguy, OCtoolguy and 1 other 3 1 Quote
Eplfan2011 Posted August 11, 2022 Author Report Posted August 11, 2022 (edited) 2 hours ago, Dak0ta52 said: I see nothing wrong with your first cut. In fact, I think it is pretty darn good! If you are familiar with Inkscape, I might suggest putting the cut lines in red and your pattern fill in a light gray. I set my stroke (lines) at .009 of an inch and try to split the line when I'm cutting. If you drift off the line, don't try to jump back onto the line quickly. Gradually work your way back toward the line. As Darryl (Ctutor) said, a light also helps. I have a lighted magnifier that makes the lines look huge and makes them much easier to follow. When I sometimes look around the magnifier straight at the pattern, I think to myself, darn those are really thin lines. Keep up the good work. You'll be jumping on some major fretwork very soon. I have a harbour freight magnifier and light, magnifier makes my eyes go funny so I just use the light lol. Thanks for the kind words but I'm gonna have to work on some of those curves they are rough 🫣 I'm pretty familiar with SVGs as I have to make my older kids custom tee shirts and vinyl stickers for their vehicles. The stuff they want usally is custom so I have to design them too. Edited August 11, 2022 by Eplfan2011 John B, Greatgrandpawrichard, Dak0ta52 and 1 other 4 Quote
Eplfan2011 Posted August 11, 2022 Author Report Posted August 11, 2022 25 minutes ago, Freddie said: What type blade did you use? Thanks in advance Flying Dutchman #3 reverse Magnifier messes with my vision too ! Greatgrandpawrichard and OCtoolguy 2 Quote
Foxfold Posted August 11, 2022 Report Posted August 11, 2022 I think it' great. I'd struggle to cut anything that thick now let alone when I first started. Well Done. !! As others have said, perhaps changing your patterns to a grey background with red lines would help, I do this to all my patterns as my old eyes lose the blade with black lines. Greatgrandpawrichard, John B and OCtoolguy 2 1 Quote
Eplfan2011 Posted August 11, 2022 Author Report Posted August 11, 2022 23 minutes ago, Foxfold said: I think it' great. I'd struggle to cut anything that thick now let alone when I first started. Well Done. !! As others have said, perhaps changing your patterns to a grey background with red lines would help, I do this to all my patterns as my old eyes lose the blade with black lines. Thanks just 3/4 pine pretty soft, I didn't realize thicker was harder to cut, probably helped me as I have a tendency to rush and I had to feed it slower. Greatgrandpawrichard and OCtoolguy 2 Quote
lawson56 Posted August 11, 2022 Report Posted August 11, 2022 Hey I think you did a Fantastic job!! You should have seen mine, it was suppose to be a Heart. but it didn't turn out so well OCtoolguy, Lucky2, John B and 1 other 2 2 Quote
Eplfan2011 Posted August 11, 2022 Author Report Posted August 11, 2022 1 minute ago, lawson56 said: Hey I think you did a Fantastic job!! You should have seen mine, it was suppose to be a Heart. but it didn't turn out so well Thanks as I said earlier I've had a bandsaw for years and the technique is pretty similar so..... Lucky2, lawson56, Greatgrandpawrichard and 1 other 4 Quote
crupiea Posted August 12, 2022 Report Posted August 12, 2022 Looks great. I put my light pretty far to the side to see the line better. That way the shadow of the blade doesnt work against me. I use a floor lamp with a bendy neck thing i got at walmart. Also a super bright light bulb. OCtoolguy, Greatgrandpawrichard and Freddie 3 Quote
OCtoolguy Posted August 12, 2022 Report Posted August 12, 2022 3 hours ago, Eplfan2011 said: I have a harbour freight magnifier and light, magnifier makes my eyes go funny so I just use the light lol. Thanks for the kind words but I'm gonna have to work on some of those curves they are rough 🫣 I'm pretty familiar with SVGs as I have to make my older kids custom tee shirts and vinyl stickers for their vehicles. The stuff they want usally is custom so I have to design them too. Maybe you can contribute in that area. I've been trying for 5 years and can barely do anything. I might become your least favorite Villager. crupiea and Greatgrandpawrichard 2 Quote
Eplfan2011 Posted August 12, 2022 Author Report Posted August 12, 2022 5 minutes ago, OCtoolguy said: Maybe you can contribute in that area. I've been trying for 5 years and can barely do anything. I might become your least favorite Villager. I'll try but I'm no expert by far, I know just enough to be dangerous. John B, Greatgrandpawrichard and OCtoolguy 1 2 Quote
Sycamore67 Posted August 12, 2022 Report Posted August 12, 2022 I had a Harbor Freight magnifier and could not stand it. I got an Ottlite magnifier light with a 3X lens and no issues. I think the quality of the optics is significantly better. Also, my magnifier is not attached to the saw so there is no vibration. Greatgrandpawrichard and OCtoolguy 2 Quote
Eplfan2011 Posted August 12, 2022 Author Report Posted August 12, 2022 4 minutes ago, Sycamore67 said: I had a Harbor Freight magnifier and could not stand it. I got an Ottlite magnifier light with a 3X lens and no issues. I think the quality of the optics is significantly better. Also, my magnifier is not attached to the saw so there is no vibration. I'm sure the lens is sub par, it's harbour freight! But saying that my eyesight is not what it used to be and I wear glasses. I don't think it's the lens because if I just look with one eye (either one) it's fine. My light is attached to the saw but there is little or no vibration and the light is steady with no movement. Greatgrandpawrichard and OCtoolguy 2 Quote
John B Posted August 12, 2022 Report Posted August 12, 2022 A pretty good effort for a first go. My 1st attempt, you'd of been surprised to know I followed a line Definitely worth getting a quality glass and light. I purchased mine many years ago from the WA Blind Institute. I don't usually wear my glasses when using the magnifier, I find that a very low power set of readers are all I need. If I wear my normal glasses It all goes to mud. Try Cutting on a red line, I always convert my patterns to Red line with a very light grey, blue or green infill. Keep on Keeping On Eplfan2011, Greatgrandpawrichard and OCtoolguy 3 Quote
Foxfold Posted August 12, 2022 Report Posted August 12, 2022 Magnifiers make me dizzy so I wear a pair of glasses over my glasses works for me John B, Eplfan2011, OCtoolguy and 1 other 4 Quote
Sycamore67 Posted August 12, 2022 Report Posted August 12, 2022 10 hours ago, Eplfan2011 said: I'm sure the lens is sub par, it's harbour freight! But saying that my eyesight is not what it used to be and I wear glasses. I don't think it's the lens because if I just look with one eye (either one) it's fine. My light is attached to the saw but there is little or no vibration and the light is steady with no movement. I had the same issue with the Harbor Fright lens. With a better lens, the sweet spot is bigger and I have both eyes open with no problem. Everyone's eyes are different so the reaction to different lens will vary. When I do Intarsia, I need to cut on one half of the line to get a good fit. I can not do that without a magnifier. OCtoolguy and Greatgrandpawrichard 2 Quote
daveww1 Posted August 12, 2022 Report Posted August 12, 2022 excellent job Greatgrandpawrichard and OCtoolguy 2 Quote
