Travis Posted November 11, 2011 Report Posted November 11, 2011 I'm curious, what thickness of plywood do you use the most for your portrait-style cuttings? 1/8" or 1/4"? Quote
TheWoodArtist Posted November 11, 2011 Report Posted November 11, 2011 I use 1/4 most of the time but every now and then when I want the light shadow effect with great detail I even use 1/2 and 3/4 but most of the time it's 1/4 on everything. Quote
Mick Posted November 11, 2011 Report Posted November 11, 2011 I use mostly 1/8" for portraits. 1/4" for scenic pictures. Mick Quote
Clayton717 Posted November 11, 2011 Report Posted November 11, 2011 I use mostly 1/8" for portraits. Quote
Dan Posted November 12, 2011 Report Posted November 12, 2011 I use 1/8" because it fits in many store-bought frames and I can stack cut more if I want. Quote
wombatie Posted November 12, 2011 Report Posted November 12, 2011 I use 2.5 or 3mm Marine ply it is very sturdy, and you don't get bits break off. Marg Quote
Marshall Posted November 12, 2011 Report Posted November 12, 2011 In the past I have used the 1/8" BB plywood ...........for I usually stack cut two or three when I'm cutting . Quote
scrollworks Posted November 13, 2011 Report Posted November 13, 2011 I use 1/8" baltic birch for my portraits, as they fit nicely into frames without modification. Quote
whywe2000 Posted November 14, 2011 Report Posted November 14, 2011 Hi I used 1/4'' for portraits . and 1/8 for backing Del. Quote
Lucky2 Posted November 17, 2011 Report Posted November 17, 2011 Travis, I use 1/8" for the portrait and for the backer also, I find that I can cut more copies if I use it because I stack cut as many as five at a time. Len Quote
