Eplfan2011 Posted August 29, 2022 Report Posted August 29, 2022 I haven't been able to get back on the saw since cutting my first project. I put off mowing my yard today and get some much needed practice in. Decided to try actually cutting a couple of patterns. The first one was posted on here( I'm sorry I forgot who posted it for credit) it's a gnome, and the second is a Steve Good pattern. Both are straight off the saw the gnome is a 1/2 scrap oak and the other is just a cheap 1/8" luan plywood scrap, I figured it's not worth using good wood yet. I still need to cut a couple of bits, then I will sand them and give them a coat of paint. I've still got a long long way to go. I'm still having a problem turning inside 90° corners consistently but I guess it's early days. The new light and magnifier worked well and I added the lockline upgrade for the blower, which is also great. Probably the most helpful addition was the foot pedal. Well I've took up enough of your time but I just have to say how much I appreciate your skills and craft after seeing your work and attempting to try and do something passable myself. Wichman, lawson56, don watson and 6 others 9 Quote
OCtoolguy Posted August 29, 2022 Report Posted August 29, 2022 26 minutes ago, Eplfan2011 said: I haven't been able to get back on the saw since cutting my first project. I put off mowing my yard today and get some much needed practice in. Decided to try actually cutting a couple of patterns. The first one was posted on here( I'm sorry I forgot who posted it for credit) it's a gnome, and the second is a Steve Good pattern. Both are straight off the saw the gnome is a 1/2 scrap oak and the other is just a cheap 1/8" luan plywood scrap, I figured it's not worth using good wood yet. I still need to cut a couple of bits, then I will sand them and give them a coat of paint. I've still got a long long way to go. I'm still having a problem turning inside 90° corners consistently but I guess it's early days. The new light and magnifier worked well and I added the lockline upgrade for the blower, which is also great. Probably the most helpful addition was the foot pedal. Well I've took up enough of your time but I just have to say how much I appreciate your skills and craft after seeing your work and attempting to try and do something passable myself. Looks good to me. Sharp corners are tough. bobscroll and Scrappile 1 1 Quote
Eplfan2011 Posted August 29, 2022 Author Report Posted August 29, 2022 5 minutes ago, OCtoolguy said: Sharp corners are tough. Seems like everything is tough for me OCtoolguy 1 Quote
Dak0ta52 Posted August 29, 2022 Report Posted August 29, 2022 Looks like great cutting to me, Colin. Glad you found time to get on the saw. OCtoolguy and Eplfan2011 1 1 Quote
Eplfan2011 Posted August 29, 2022 Author Report Posted August 29, 2022 49 minutes ago, Dak0ta52 said: Looks like great cutting to me, Colin. Glad you found time to get on the saw. Thanks, a million mistakes , but I'll get there eventually. OCtoolguy 1 Quote
OCtoolguy Posted August 29, 2022 Report Posted August 29, 2022 You are being way too hard on yourself. Your work is great and will just get better. The material you use can make a big difference. Also Steve Good has a very good video regarding how to cut square corners. Quote
Eplfan2011 Posted August 29, 2022 Author Report Posted August 29, 2022 Thanks Ray, Yep I trolled youtube and found his video and a few others, it will click eventually, and yes I am hard on myself but that's just the way I'm made. I'm impatient and like to get stuff knocked out, I've got to remind myself to slow down and to be patient , the weather will be changing pretty soon and I'll have plenty of time to spend down here, and I know I'll improve. OCtoolguy 1 Quote
Foxfold Posted August 29, 2022 Report Posted August 29, 2022 Looking good, that's some nice work you've done. Don't fret over corners, I've been scrolling 4 yrs and still approach the corners from both sides rather than do a full turn OCtoolguy and Eplfan2011 1 1 Quote
don watson Posted August 29, 2022 Report Posted August 29, 2022 I think your work is great. You are being a bit hard on yourself but we all are I think. Definitely good work there. Eplfan2011 and OCtoolguy 1 1 Quote
lawson56 Posted August 29, 2022 Report Posted August 29, 2022 Love the Flag Awesome job on that!!! The Gnome looks Fantastic!!! Your corners are Great!!! OCtoolguy and Eplfan2011 1 1 Quote
daveww1 Posted August 29, 2022 Report Posted August 29, 2022 your work is very nice Eplfan2011 and OCtoolguy 1 1 Quote
barb.j.enders Posted August 29, 2022 Report Posted August 29, 2022 Very nice cutting. I believe the gnome was done by Don in Brooklin. !0+ years and I still don't do great on corners; that's what files are for OCtoolguy and Eplfan2011 1 1 Quote
Wichman Posted August 29, 2022 Report Posted August 29, 2022 (edited) " I'm still having a problem turning inside 90° corners consistently but I guess it's early days. " What blades are you using? Standard blades and MGT blades cut differently and need different techniques. Standard blades have a " burr " on one side ( generally the right hand side ) and will turn better if cutting into the burr. Edited August 29, 2022 by Wichman OCtoolguy 1 Quote
Eplfan2011 Posted August 29, 2022 Author Report Posted August 29, 2022 1 hour ago, Wichman said: What blades are you using? Standard blades and MGT blades cut differently and need different techniques. Standard blades have a " burr " on one side ( generally the right hand side ) and will turn better if cutting into the burr. Thanks for the info Wichman! I'm using FD ultra reverse at the moment, being as I'm new at this I'll be trying others. I should have used a smaller blade on the flag I realize that now, I was cutting 1/2 oak with a #5 just before and just continued using it to do the flag. OCtoolguy 1 Quote
OCtoolguy Posted August 29, 2022 Report Posted August 29, 2022 5 minutes ago, Eplfan2011 said: Thanks for the info Wichman! I'm using FD ultra reverse at the moment, being as I'm new at this I'll be trying others. I should have used a smaller blade on the flag I realize that now, I was cutting 1/2 oak with a #5 just before and just continued using it to do the flag. I use a #5 mgt Pegas on almost everything I do. don watson 1 Quote
savethebeer Posted August 29, 2022 Report Posted August 29, 2022 21 hours ago, Eplfan2011 said: . I put off mowing my yard today and get some much needed practice in. When you've put off mowing, painting, changing the oil, going outside, eating food whilst its at least warm, getting your hair cut, Even after all that you'll still feel that you need 'some much needed practice' so thats perfectly normal. Those cuttings look fine to the rest of us but you'll always know the one corner on a piece where you could have done better. Just remember, once the pattern is removed then no one else will ever be able to see anything wrong. Bob OCtoolguy 1 Quote
Eplfan2011 Posted August 29, 2022 Author Report Posted August 29, 2022 40 minutes ago, savethebeer said: When you've put off mowing, painting, changing the oil, going outside, eating food whilst its at least warm, getting your hair cut, Even after all that you'll still feel that you need 'some much needed practice' so thats perfectly normal. Those cuttings look fine to the rest of us but you'll always know the one corner on a piece where you could have done better. Just remember, once the pattern is removed then no one else will ever be able to see anything wrong. Bob Thanks Bob, I'm just in a hurry to learn, I've had the saw a month and that's only the third time I've got to saw. I see all the beautiful stuff you guys are churning out and I want to be there .... I know be patient OCtoolguy 1 Quote
OCtoolguy Posted August 30, 2022 Report Posted August 30, 2022 2 hours ago, Eplfan2011 said: Thanks Bob, I'm just in a hurry to learn, I've had the saw a month and that's only the third time I've got to saw. I see all the beautiful stuff you guys are churning out and I want to be there .... I know be patient I would say that you have been bit by the bug. For sure. It will only get worse. don watson 1 Quote
Eplfan2011 Posted August 30, 2022 Author Report Posted August 30, 2022 35 minutes ago, OCtoolguy said: I would say that you have been bit by the bug. For sure. It will only get worse. Well I needed a new hobby Lmao OCtoolguy and don watson 1 1 Quote
TAIrving Posted August 30, 2022 Report Posted August 30, 2022 On 8/28/2022 at 10:02 PM, Eplfan2011 said: Thanks, a million mistakes , but I'll get there eventually. Welcome to the obsession hobby! Your work will get better. Save these first few cuttings. In the future you can compare what you are doing to these and see how much you have improved. OCtoolguy and Eplfan2011 2 Quote
Eplfan2011 Posted August 30, 2022 Author Report Posted August 30, 2022 14 hours ago, OCtoolguy said: I would say that you have been bit by the bug. For sure. It will only get worse. I hope not, I already have a pretty long shopping list ... Which may or may not include another saw, I'm thinking one is not enough?...right? ..... OCtoolguy 1 Quote
Scrappile Posted August 30, 2022 Report Posted August 30, 2022 That is some nice cutting. Keep stepping up the challenge... You are well on your way.. OCtoolguy 1 Quote
Eplfan2011 Posted August 30, 2022 Author Report Posted August 30, 2022 1 hour ago, Scrappile said: That is some nice cutting. Keep stepping up the challenge... You are well on your way.. Thanks Scrappile ! OCtoolguy 1 Quote
Blaughn Posted August 31, 2022 Report Posted August 31, 2022 (edited) When I was teaching my grandkids to use the scrollsaw I had them do an exercise that helped them learn to turn corners with confidence. Drill an appropriate size pilot hole for the blade you are using. Then feed the blade through the hole and get it properly tensioned. Put slight pressure on the back of the blade with the stock. Start the saw and practice rotating the stock around the pilot hole with constant, very gentle pressure on the back of the blade. It gives you a feel for the turning tight corners and gives you confidence that you can make a turn without the teeth cutting the stock. Bruce Edited August 31, 2022 by Blaughn OCtoolguy, Eplfan2011, Gene Howe and 1 other 1 3 Quote
OCtoolguy Posted August 31, 2022 Report Posted August 31, 2022 19 hours ago, Blaughn said: When I was teaching my grandkids to use the scrollsaw I had them do an exercise that helped them learn to turn corners with confidence. Drill an appropriate size pilot hole for the blade you are using. Then feed the blade through the hole and get it properly tensioned. Put slight pressure on the back of the blade with the stock. Start the saw and practice rotating the stock around the pilot hole with constant, very gentle pressure on the back of the blade. It gives you a feel for the turning tight corners and gives you confidence that you can make a turn without the teeth cutting the stock. Bruce That's an excellent suggestion. Learning to put tension on the back side of the blade when approaching a sharp turn is key. I've never tried this but I've heard that taking a medium grit stone to the back edges of your blades will help too. I've also heard the same regarding bandsaw blades. Blaughn 1 Quote
