Looking at the blade I have the waste on the left, so I guess I am cutting like you, counter clockwise. I have cut the other direction depending on what I am cutting. Have been doing it that way for 19 years.
Mick
I find myself cutting in both clockwise and counter clockwise directions. It all depends on the pattern and how the blade is cutting. If I'm cutting an area that is delicate with little margin for error, I'll cut from which ever direction I feel I have the best control and least risk of overcutting.
Generally speaking, for fretwork, I start in the middle and work toward the outside, cutting the most fragile areas first.
I work from the inside to the outside, cutting the smallest holes first, then moving to larger ones. I'll cut both directions but I often use the bur (from the stamping process) on the blade to "file" problem areas such as nibs.
