I would like to know how to search for posts I have made on this site, if anyone can explain it simply I will be very gratefull.
I have made those compound cut name cube things and have posted the result on this site (somewhere). I can no longer find the patterns/method of making them and need to download the instructions from somewhere, can anyone help ?? please. I can post a pic of the name block that I have if it will help.
@don watson, there are lots of youtube videos that might be of help. I have made one nameplate that had my name on one side and my wife's on the other. Nothing too difficult about it. Just make sure you have the center line absolutely centered on the edge of your block and that your block is a true 90 degrees on all sides.
Don, did you perhaps use Steve Good's Compound keychain name system to create?
1576203136_ScreenShot2022-09-23at4_50_42PM.thumb.png.3b503f9d8dfda145531972b03de6e5ac.png
f you go up to your user name (its in the top right corner on my computer) and click and drag down - you will see "attachments" - the will let you view all the images/photos you have ever attached or added here in the Village.
1886666119_ScreenShot2022-09-23at4_52_23PM.thumb.png.1fe3c2a6e19d1b5034cbd7521dc55ae7.png
You can also see all the threads you have posted by clicking on your user name, drag down to select profile, and once at profile page - select the "See my activity" block over to the right side (its the blue box and while I hovered over it it shows the popup to see meflick's Content - select the blue box by clicking on it) and it will show what you have posted.  You could have to filter through if its been a while since you shared.
1935505908_ScreenShot2022-09-23at4_55_54PM.thumb.png.d8ef37fe568bef0dd8837ce0f855d996.png
Just some other ways to find things you have shared in the past.
Thanks again for the help. I have looked through all my posts and found the name blocks that I was after but there is no way I can find how to make them. I will start again and see if I can work out the method. I believe it is done in Inkscape so that is a start. Many thanks again.
