Needmore Posted September 27, 2022 Report Posted September 27, 2022 Has anyone made/built a circle sanding jig? I need to sand the outside edge of scroll saw projects. OCtoolguy 1 Quote
OCtoolguy Posted September 27, 2022 Report Posted September 27, 2022 Gonna need more info on this request. Maybe a pic or two of what you are working on. Quote
Eplfan2011 Posted September 27, 2022 Report Posted September 27, 2022 (edited) 5 hours ago, Needmore said: Has anyone made/built a circle sanding jig? I need to sand the outside edge of scroll saw projects. Check out Steve good's videos on YouTube, I'm sure he has one on there. Edit .... I just looked, I didn't see it but found many others just search circle sanding jig. Edited September 27, 2022 by Eplfan2011 OCtoolguy 1 Quote
Scrappile Posted September 27, 2022 Report Posted September 27, 2022 Here is what I use. Very basic. Of coarse with this on you have to have a center hole in the working piece. You can drill holes in the slider to fit the hole in your circle. O used this mainly when making wheels and gears. works pretty well, but downside only on something you are willing to have a center hole in. danny, OCtoolguy and Lucky2 2 1 Quote
Lucky2 Posted September 28, 2022 Report Posted September 28, 2022 Paul, could you please let me know, what happens to the tightening knob, when you flip the jig over to use the jig? Does it not get stuck, right in the way of things? Len OCtoolguy 1 Quote
Needmore Posted September 28, 2022 Author Report Posted September 28, 2022 Thanks every one I'll try the one that Steve Good has on youtude. OCtoolguy 1 Quote
BadBob Posted September 28, 2022 Report Posted September 28, 2022 This should give you some ideas. danny and OCtoolguy 1 1 Quote
Wichman Posted September 28, 2022 Report Posted September 28, 2022 One additional note. If you are trying to true up a circle without a center hole, create a blank circle with a hole, then attach the blank without a hole on top with double stick tape or adhesive, sand and remove. danny, Gene Howe and OCtoolguy 1 2 Quote
Scrappile Posted September 28, 2022 Report Posted September 28, 2022 10 hours ago, Lucky2 said: Paul, could you please let me know, what happens to the tightening knob, when you flip the jig over to use the jig? Does it not get stuck, right in the way of things? Len I only use that jig on my disc belt sander. It has a small table. The knob is set far enough back to miss the table. I loosen it so the slider will slide, put the jig on the table, and set the slide to slide the project up to the sander, then reach under and tighten the knob. The knob bolt screws up against the slider and holds it in place. I do not flip the jig over, the first picture is the jug set in place the last picture is just to show what the bottom of the jig looks like. Lucky2 and OCtoolguy 2 Quote
Lucky2 Posted September 30, 2022 Report Posted September 30, 2022 Thanks Paul, now I can envision it. Len Quote
