Popular Post munzieb Posted September 30, 2022 Popular Post Report Posted September 30, 2022 A few weeks ago I noticed that I wasn't getting any air out of my blower on my EX 16. I proceeded to open the plate on the bottom that holds the bellows in place. A piece of rubber fell out and it looked to have a whole. Oh my! I was long out of warranty and what to do. I had good luck working with Denny at Artcrafter and he contacted Pegas and was able to get me a bellows. It came today and I will install it this weekend. You are my go to guy! Thank you Denny, Scrappile, meflick, OCtoolguy and 14 others 16 1 Quote
Lucky2 Posted September 30, 2022 Report Posted September 30, 2022 Yeah Munzieb, that piece of rubber sure could block, the air supply to your dust remover. Good fix, and I agree that, Denny is our go to guy. Len OCtoolguy and barb.j.enders 2 Quote
Scrappile Posted September 30, 2022 Report Posted September 30, 2022 Seyco has them also. But not positive they are the same. Seyco's listed are for Excalibur. John B, OCtoolguy, scrollingforsanity and 1 other 4 Quote
OCtoolguy Posted September 30, 2022 Report Posted September 30, 2022 If I'm reading this correctly, you have an Excalibur 16. Am I to understand that the Pegas bellows is different? I'd have thought they would be the same. Curious! Quote
Lucky2 Posted October 1, 2022 Report Posted October 1, 2022 Ray, why would you think that, each saw is manufactured by different companies. They wouldn't be allowed, to copy the EX exactly the same, due to copyright protection. A minor change such as this, would go towards the percentage of changes they need to bring their saws to market. I'm not sure of what the percentage is, but, it's out there somewhere in a patent lawyers bag of tricks. That's how Saw-Stop has gotten so much protection, they patented almost every piece of their saws separately. Doing so, makes it almost impossible, to make a saw using any of the Saw-Stop technology. Len OCtoolguy 1 Quote
munzieb Posted October 1, 2022 Author Report Posted October 1, 2022 23 hours ago, OCtoolguy said: If I'm reading this correctly, you have an Excalibur 16. Am I to understand that the Pegas bellows is different? I'd have thought they would be the same. Curious! Ray, The new bellows looked identical to the one I removed. It took a little to figure out how to install it. There is a hole at the bottom where the plate is mounted but there is no way to install it that way (especially with thick fingers)I removed the 4 screws that connect the upper housing cover to the square aluminum plate at the front where the 3 rods pass through. I removed the small bolt on the top that connects the 2 drive arms. This arm has a bushing and 2 Shims on either side. This arm has the pin to mount the bellows on the underside and can be removed ( a whole lot easier!) Reinstalled everything and it all works good. OCtoolguy and John B 1 1 Quote
OCtoolguy Posted October 1, 2022 Report Posted October 1, 2022 3 hours ago, munzieb said: Ray, The new bellows looked identical to the one I removed. It took a little to figure out how to install it. There is a hole at the bottom where the plate is mounted but there is no way to install it that way (especially with thick fingers)I removed the 4 screws that connect the upper housing cover to the square aluminum plate at the front where the 3 rods pass through. I removed the small bolt on the top that connects the 2 drive arms. This arm has a bushing and 2 Shims on either side. This arm has the pin to mount the bellows on the underside and can be removed ( a whole lot easier!) Reinstalled everything and it all works good. I'm still confused. Couldn't Denny have just sent you a Pegas bellows? 4 hours ago, Lucky2 said: Ray, why would you think that, each saw is manufactured by different companies. They wouldn't be allowed, to copy the EX exactly the same, due to copyright protection. A minor change such as this, would go towards the percentage of changes they need to bring their saws to market. I'm not sure of what the percentage is, but, it's out there somewhere in a patent lawyers bag of tricks. That's how Saw-Stop has gotten so much protection, they patented almost every piece of their saws separately. Doing so, makes it almost impossible, to make a saw using any of the Saw-Stop technology. Len Many of the parts on the Pegas are interchangeable between brands. Not sure about all but I'd have thought the bellows might have been the same. Just asking for future needs as I have 2 Ex's and if I can buy parts from Denny it becomes another source. Lucky2 1 Quote
OCtoolguy Posted December 6, 2022 Report Posted December 6, 2022 I placed an order for a gross of blades Friday 12/2. Received them today 12/4. Tennessee to So Cal. Darned quick. And, because me last order with Denny was a set of Pegas clamps, I rec'd 6 dozen blades for free. Best service ever. Thanks Denny & crew. Dak0ta52, Dave Monk, scrollingforsanity and 1 other 4 Quote
Denny Knappen Posted December 6, 2022 Report Posted December 6, 2022 15 hours ago, OCtoolguy said: I placed an order for a gross of blades Friday 12/2. Received them today 12/4. Tennessee to So Cal. Darned quick. And, because me last order with Denny was a set of Pegas clamps, I rec'd 6 dozen blades for free. Best service ever. Thanks Denny & crew. Thanks Ray. What you are referring to is my Loyal Customer Program. Free blades based on the amount of the previous order. OCtoolguy, Dak0ta52 and Roberta Moreton 2 1 Quote
Woodrush Posted December 7, 2022 Report Posted December 7, 2022 On 9/30/2022 at 4:31 PM, OCtoolguy said: If I'm reading this correctly, you have an Excalibur 16. Am I to understand that the Pegas bellows is different? I'd have thought they would be the same. Curious! Jim Blume and I compared part #s from his pegas to my Canadian king. All but one bearing are the same OCtoolguy and John B 1 1 Quote
