Millwab Posted October 7, 2022 Report Posted October 7, 2022 I was able to pick up an old Hegner Multimax 2 for $50. The only thing I can find wrong with it is that the bellows needs to be replaced. I checked the Advanced Machinery website but they don’t appear to offer a replacement. Any suggestions? jbrowning and OCtoolguy 2 Quote
OCtoolguy Posted October 7, 2022 Report Posted October 7, 2022 (edited) I replaced 2 of them using CV boots. Worked great. Just get the measurements at top and bottom and go looking. I can't recall what I used. I'll do some research and try to find my Amazon purchase. BRB. Here ya go. Kit Empi 86-2340D from Amazon was under $20. Edited October 7, 2022 by OCtoolguy ChelCass and Dan 2 Quote
CharleyL Posted October 7, 2022 Report Posted October 7, 2022 A small aquarium air pump works great if you can't find a replacement bellows for your saw. Wire it and the saw to both run from a foot switch and it will only run when you are running the saw. Charley Dan, Roberta Moreton, Fish and 2 others 5 Quote
Millwab Posted October 8, 2022 Author Report Posted October 8, 2022 (edited) 9 hours ago, OCtoolguy said: I replaced 2 of them using CV boots. Worked great. Thanx Ray. I’ll check the auto parts store tomorrow and see what they have. Did you need to use the band clamps or was the fit tight enough? 7 hours ago, CharleyL said: A small aquarium air pump works great if you can't find a replacement bellows for your saw. Wire it and the saw to both run from a foot switch and it will only run when you are running the saw. Charley, I was hoping to not have to add another device on to the saw. I think the previous owner (not who I bought it from) must have used one because the air tube was cut in half. I don’t use a foot switch because of my back problems. I need to keep changing position while I’m sawing and a foot switch would make that difficult. Edited October 8, 2022 by Millwab OCtoolguy 1 Quote
Scrappile Posted October 8, 2022 Report Posted October 8, 2022 ADVANCED MACHENERY DOES HAVE THEM, BUT LIKE ALL HEGNER PARTS YOU PAY FOR THEN: https://advanced-machinery.myshopify.com/products/m22-v-part-number-017-bellows You could buy three of what Ray suggests, if they work and have two spares on hand. Quote
Scrappile Posted October 8, 2022 Report Posted October 8, 2022 22 hours ago, OCtoolguy said: I replaced 2 of them using CV boots. Worked great. Just get the measurements at top and bottom and go looking. I can't recall what I used. I'll do some research and try to find my Amazon purchase. BRB. Here ya go. Kit Empi 86-2340D from Amazon was under $20. Ray, did the top of that boot stretch enough to fit over what it has to fit over on the saw? My saw is not around 12 years old, Maybe I should buy what you did and have on hand. I will forget about it if the time comes I need one,, heck I will forget about it in 10 minutes! Of course, I would also forget where I stored the spare if I happen to remember I had one. OCtoolguy and stoney 2 Quote
OCtoolguy Posted October 8, 2022 Report Posted October 8, 2022 27 minutes ago, Scrappile said: Ray, did the top of that boot stretch enough to fit over what it has to fit over on the saw? My saw is not around 12 years old, Maybe I should buy what you did and have on hand. I will forget about it if the time comes I need one,, heck I will forget about it in 10 minutes! Of course, I would also forget where I stored the spare if I happen to remember I had one. Paul, it's a perfect fit both top & bottom. Quote
OCtoolguy Posted October 8, 2022 Report Posted October 8, 2022 12 hours ago, Millwab said: Thanx Ray. I’ll check the auto parts store tomorrow and see what they have. Did you need to use the band clamps or was the fit tight enough? Charley, I was hoping to not have to add another device on to the saw. I think the previous owner (not who I bought it from) must have used one because the air tube was cut in half. I don’t use a foot switch because of my back problems. I need to keep changing position while I’m sawing and a foot switch would make that difficult. No clamps needed. Quote
redwine Posted October 8, 2022 Report Posted October 8, 2022 20 hours ago, CharleyL said: A small aquarium air pump works great if you can't find a replacement bellows for your saw. Wire it and the saw to both run from a foot switch and it will only run when you are running the saw. Charley This is what I had to do with my Delta P20! The part that the bellows mounted on broke in half and the part was no longer available! I had an aquarium air pump that had been used on another saw that i sold and decided to hook it up to the P20. It actually puts out more air than the original bellows did and it is hooked up to run when the saw does and shuts off when the saw does! Erv Roberta Moreton, Lucky2, danny and 1 other 4 Quote
