Popular Post kmmcrafts Posted October 12, 2022 Popular Post Report Posted October 12, 2022 (edited) I was asked a while back to make a snowmobile clock. The customer sent an image of basically a half circle with a snowmobile silhouette. While they did a nice job on the cutting and even design wasn’t too bad but I felt there was a lot of air space with nothing in it. So I designed this by combining a few different patterns to create one. Cut from Cherry using my Hawk saw with a #5 Pegas MFG blade. Finished with Danish oil, may put a top coat of poly on it in a few days as it’s currently drying ( dipped today ). I'm kind od torn on whether I should have cut the hill area on the right by his head off.. kind of blends into his head. Edited October 12, 2022 by kmmcrafts jbrowning, Eplfan2011, RabidAlien and 11 others 14 Quote
Roberta Moreton Posted October 13, 2022 Report Posted October 13, 2022 1 hour ago, kmmcrafts said: I was asked a while back to make a snowmobile clock. The customer sent an image of basically a half circle with a snowmobile silhouette. While they did a nice job on the cutting and even design wasn’t too bad but I felt there was a lot of air space with nothing in it. So I designed this by combining a few different patterns to create one. Cut from Cherry using my Hawk saw with a #5 Pegas MFG blade. Finished with Danish oil, may put a top coat of poly on it in a few days as it’s currently drying ( dipped today ). I'm kind od torn on whether I should have cut the hill area on the right by his head off.. kind of blends into his head. I do see what you mean, but I didn’t see a problem. I think it’s good as is. kmmcrafts 1 Quote
wombatie Posted October 13, 2022 Report Posted October 13, 2022 When I first looked at it, I thought the same as you Kevin but after taking a closer look I don't think it's a problem. You did a great job of a mash up. Marg kmmcrafts 1 Quote
