barb.j.enders Posted October 25, 2022 Report Posted October 25, 2022 On 10/24/2022 at 4:25 PM, kmmcrafts said: Apply it with a acid brush and use a hair dryer or heat gun to melt it into the crevasse etc. If you melt the mixture into the crevasses etc, how do you buff them out? Or is that needed??? Quote
kmmcrafts Posted October 25, 2022 Report Posted October 25, 2022 4 minutes ago, barb.j.enders said: If you melt the mixture into the crevasses etc, how do you buff them out? Or is that needed??? No need to buff it out.. the heat and the air blowing from the hair dryer sort of melts and blows the excess off and out the back side.. Wipe off excess with paper towels.. barb.j.enders, OCtoolguy and Eplfan2011 2 1 Quote
Gene Howe Posted October 29, 2022 Report Posted October 29, 2022 Rustoleum clear enamel has replaced the Minwax spray products in my shop. OCtoolguy 1 Quote
MrsN Posted October 30, 2022 Report Posted October 30, 2022 I use rustoleum clear gloss on most everything. It comes in gloss, semi gloss and satin. I like that it isn't yellowish, so works on painted stuff. Plus I can get it at several places locally. OCtoolguy and John B 1 1 Quote
Zoot Fenster Posted October 31, 2022 Report Posted October 31, 2022 I have tried a number of spray can finishes. I like flat sheen. YMMV. The polyurethanes took too long to dry, but the best was the Deft exterior semi-gloss. Spray lacquers tried much faster. Mohawk exterior flat is the current favorite and quite affordable. "Dead flat" is too flat, even for me. Eplfan2011 and OCtoolguy 2 Quote
