BadBob Posted November 1, 2022 Report Posted November 1, 2022 I have seen several places that recommend adding a sandbox to a scroll saw stand to reduce vibration. It's in one of Nick Engler's books, for sure. It is a sealed wood box full of sand mounted to the base of the scroll saw to reduce vibration. Have you built one of these? OCtoolguy 1 Quote
Foxfold Posted November 1, 2022 Report Posted November 1, 2022 I haven't heard of this, but it sounds like a good idea. I have mine bolted to my work bench with a piece of 2"x2" under the back of the saw.. There will be a fair few answers to this question I would imagine as most seem to have scrollsaw stands. OCtoolguy 1 Quote
Joe W. Posted November 1, 2022 Report Posted November 1, 2022 I've seen a "sandbox" article as well, but opted to use two layers of 1 1/4" thick boards, giving me a 2 1/2" base with a layer of thick carpet between the board and the scroll saw. No problems with vibration. Foxfold and OCtoolguy 2 Quote
Puzzleguy Posted November 1, 2022 Report Posted November 1, 2022 (edited) When we first moved to where we are now , I had alot of problems with my polymax - it shook like crazy , i tried making a large square work bench thinking it might work , it didnt - I tried a recycled rubber mat ( about a 1 1/2' thick - didnt work - So i took a view point of doing it right so i cut a area out of my floor ( between joists ) used the iron rebars , crossed them , wired them together - and had a concrete pad poured - made it big enough for three saws - and it is great . Not a cheap solution - but a commercial solution Edited November 1, 2022 by Puzzleguy OCtoolguy 1 Quote
Scrappile Posted November 1, 2022 Report Posted November 1, 2022 have my excalibur and Seyco mounted on a cabinet I built. I purt a bag of concrete in the bottom.. It helped some. The cabinet was on castors so it was part of the problem. OCtoolguy 1 Quote
