zimmerstutzen Posted November 3, 2022 Report Posted November 3, 2022 (edited) I am primarily a turner, but I make a lot of ornaments for charity and use the scroll saw in the process. I need to cut some silhouettes of figures (whales, shakes, flip flops, boats, etc) and also the biggest pain was cutting 1/4 inch and under dowels to equal length without splintering them. The table saw was simply out of the question for such little work, same for the band saw. I tried measuring and marking the dowels and cutting them on the scroll saw but got too many differing lengths that were a pain to even out. So I came up with a idea. I used two HF shop spring clamps and a new paint mixing stick to make a fence on the right side of the table. I measured the distance from the saw blade to the paint stick to get 2.5 inches and then proceeded to cut a 36 inch 1/4 inch dowel into 2.5 inch sections. I went slow through the blade and kept splintering edges to a very bare minimum and was happy when I stood them on end and all but the last were dead even in length. Edited November 3, 2022 by zimmerstutzen Lucky2, Dak0ta52, OCtoolguy and 6 others 8 1 Quote
WayneMahler Posted November 4, 2022 Report Posted November 4, 2022 Nice work, look's great. I use a bench hook and Japanese pull saw. Clean quick and dependable. As for length, set up a stop block, slide the dowel over cut, repeat. kmmcrafts, OCtoolguy and Lucky2 3 Quote
BadBob Posted November 4, 2022 Report Posted November 4, 2022 I use a fine tooth Japanese dozuki saw for cutting dowels using this. It can cut through 1/4-inch dowels in a single stroke of the saw with very little. kmmcrafts, barb.j.enders and OCtoolguy 3 Quote
