Tallbald Posted November 6, 2022 Report Posted November 6, 2022 I find myself asking if the repeating patterns I see on most commercial puzzles are some sort of standardized pattern everyone but me knows about and uses, or are there bunches and bunches of talented crafters that freehand these patterns for themselves with each creation? And, should I/could I freehand a page of the interlocking piece lines and then simply overlay that on puzzles of my own design after outlining the overall piece? Inquiring minds want to know. Thank you. Don OCtoolguy 1 Quote
Gene Howe Posted November 6, 2022 Report Posted November 6, 2022 There's a fellow on the Gwinnet Woodworkers You Tube channel that does a lot of puzzles. He doesn't use any patterns. Just uses and repeats the normal interlocking puzzle joint. Because he doesn't use a pattern, each puzzle is different and, he can vary the complexity. OCtoolguy 1 Quote
barb.j.enders Posted November 6, 2022 Report Posted November 6, 2022 Steve Good has a pattern book for "standard" interlocking puzzles. OCtoolguy and Roberta Moreton 2 Quote
Dan Posted November 6, 2022 Report Posted November 6, 2022 I cut mine freehand. I find it more difficult and time consuming to use a pattern. Once you do one or two you'll get the hang of it. Besides, you can be more creative and cut various shapes to go with a theme. OCtoolguy, Gene Howe and John B 3 Quote
Tallbald Posted November 6, 2022 Author Report Posted November 6, 2022 I always freehanded my turnings for my sculptures. My mind's eye saw what needed to be. I think I'll attempt freehand drawing the interlocking pieces also. I can always make a pattern that I can use as needed. Suggest a book please friends about puzzle crafting? Amazon is my friend. Thanks. Don OCtoolguy 1 Quote
John B Posted November 7, 2022 Report Posted November 7, 2022 (edited) I vary my approach, Some times I cut freehand and cut various shapes and whimsies, other times (Especially if there are a lot of pieces) I use a pattern. You really only need to do a search for "Jigsaw Puzzle Templates" and there are plenty. Just grab the one with the most pieces then use how many pieces you need for your puzzles. I print it on thin card, tape the card to the front of the puzzles and away I go. You can either shrink or enlarge the pattern or just use a part of it, once again shrinking or enlarging that part. Edited November 7, 2022 by John B Quote
Tom-in-Ashland Posted November 7, 2022 Report Posted November 7, 2022 I always cut mine free hand. And would sometimes cut diagonally into the corner so there were no 90 degree cones pieces to help start assembly. Quote
Millwab Posted November 7, 2022 Report Posted November 7, 2022 If I’m not cutting it along the color lines of the picture I cover the picture with shelf liner and draw a grid on it to keep my rows & columns straight. Either horizontally/vertically or on a diagonal depending on how many pieces and how difficult I want it to be. Then it’s freehand cutting the locks. An interesting twist to the diagonal grid is that all the outside pieces are triangles that don’t interconnect except in the corners. Gene Howe 1 Quote
Tallbald Posted November 7, 2022 Author Report Posted November 7, 2022 These are great! Thank you each and all. Don Quote
Puzzleguy Posted November 7, 2022 Report Posted November 7, 2022 even if you use a pattern , every puzzle will be different unless your a machine - John B 1 Quote
