Popular Post Dak0ta52 Posted November 27, 2022 Popular Post Report Posted November 27, 2022 This is the piece that was a double stack and delaminated when I removed the painter's tape. I finally got around to adding a little color in hopes of covering up the delamination. This piece is cut on 1/4-inch Birch ply stained Natural with a 1/4-inch Birch backer board stained Espresso. The coloring is watercolor. After staining and coloring it was sprayed with several coats of polyacrylic sanded with 600 grit between coats. This was the first time using my new spray gun to spray the finish. Frame is pre-made framing material that I scuffed and restained with espresso to darken it up where it would be tinted closer to the backer board. The pattern is by Birchbark. ChelCass, Scrappile, meflick and 8 others 11 Quote
Peter N White Posted November 27, 2022 Report Posted November 27, 2022 you have done very good. Dak0ta52 1 Quote
Charlie E Posted November 28, 2022 Report Posted November 28, 2022 Nice job covering the problem. Can you do anything with tattoos? Dak0ta52 and Gene Howe 2 Quote
Dak0ta52 Posted November 28, 2022 Author Report Posted November 28, 2022 2 hours ago, Charlie E said: Nice job covering the problem. Can you do anything with tattoos? Sure Charlie!!! I could cover a tattoo with no problem... but it would only last until you took a shower. After all, it is watercolor! Charlie E and Gene Howe 2 Quote
