I bought some of these 1/4 sheet pads Friday.  I have not used them enough to talk about durability yet but these things really cut.  I have used the 120 and 180 grit on Poplar boards and they leave almost a glass like finish at the 180 level.  Might be worth a try if your are in the market.
https://www.harborfreight.com/painting/painting-supplies/sandpaper-sheets/4-12-in-x-5-12-in-60-grit-14-sheet-sandpaper-with-ceramic-alumina-grain-5-pack-58136.html
Personally, I have tried their sandpaper and gotten very inconsistent results.  After spending a lot of time making and sanding something, I find it leaves a few odd scratches.  Maybe on small things not an issue but on larger surfaces, it is a problem.
Now, I use only Klingspor or Norton products.  More expensive but better results.
