Popular Post FrankEV Posted December 12, 2022 Popular Post Report Posted December 12, 2022 Steve Good recently issued a pattern for a Heart Tray. I had some Maple and Padauk boards left over from the Heart Box I made back last February (https://www.scrollsawvillage.com/forums/topic/45466-my-version-of-dave-monk%E2%80%99s-%E2%80%98box-for-valentines-day%E2%80%99/#comment-486165). I thought the Tray would make a good companion for the Box I gave my Lady. Was going to give it to her on Christmas but she saw and claimed it already. Laminated the Maple and Padauk making the tray walls 1 1/4” high. Stack cut the outside of laminated tray walls along with the 1/8” thick maple bottom first, then after removing the bottom, cut out the interior sections. Fairly easy cutting with Pegas #5 Skip tooth Blade. Lot of hand sanding creating the red dust everywhere. Attached bottom to walls with Superglue and applied multiple coats of Deft Clear Gloss Lacquer. Used the inside dropouts to trace and cut out the red felt bottom liner which I attached with spray adhesive. PITA to fit the sticky liner in its proper place. Comments and Critiques always welcome Phantom Scroller, barb.j.enders, John B and 13 others 16 Quote
Blaughn Posted December 12, 2022 Report Posted December 12, 2022 Nice Job. I'll bet that was a bear to sand before Finishing!!! Bruce Quote
FrankEV Posted December 12, 2022 Author Report Posted December 12, 2022 33 minutes ago, Blaughn said: Nice Job. I'll bet that was a bear to sand before Finishing!!! Bruce My cutting was pretty neat, so it did not require a lot of sanding. Just needed to smooth everything with a fine grit and fix up the tight intersections a little. However, cutting and sanding Padauk creates that fine red dust that gets all over everything. Although it feel dry, it stick to all surfaces like filings on a magnet. Blaughn 1 Quote
Blaughn Posted December 13, 2022 Report Posted December 13, 2022 5 hours ago, FrankEV said: My cutting was pretty neat, so it did not require a lot of sanding. Just needed to smooth everything with a fine grit and fix up the tight intersections a little. However, cutting and sanding Padauk creates that fine red dust that gets all over everything. Although it feel dry, it stick to all surfaces like filings on a magnet. I hope you are using a mask. I have just finally surrendered and begun to wear one while scrolling and especially sanding. FrankEV 1 Quote
daveww1 Posted December 13, 2022 Report Posted December 13, 2022 very nice, it's beautiful FrankEV 1 Quote
Ron Johnson Posted December 27, 2022 Report Posted December 27, 2022 You did a real beautiful job Frank. The Padauk and Maple make a great combination. Happy New Year. FrankEV 1 Quote
