Bowser Posted December 26, 2022 Report Posted December 26, 2022 JUST MOVE THIS SAW FROM FATHERS HOUSE TO MINE...I HAVE NEVER SEEN IT RUN. PLUG IT IN AND SWITCH IT ON AND NOTHING HAPPENS...IS THERE A FUSE SITUATION? ANY HELP WITH THIS PROBLEM WOULD BE GREAT THANKS IN ADVANCE OCtoolguy 1 Quote
bscroller Posted December 26, 2022 Report Posted December 26, 2022 3 hours ago, Bowser said: JUST MOVE THIS SAW FROM FATHERS HOUSE TO MINE...I HAVE NEVER SEEN IT RUN. PLUG IT IN AND SWITCH IT ON AND NOTHING HAPPENS...IS THERE A FUSE SITUATION? ANY HELP WITH THIS PROBLEM WOULD BE GREAT THANKS IN ADVANCE make sure the cable from the motor to the speed control is attached they will seperate or come loose Woodrush and OCtoolguy 2 Quote
Dan Posted December 26, 2022 Report Posted December 26, 2022 If you go here http://www.rbiwoodtools.com/WebsitePages/Scroll-Saw-Manuals.html they have a list of manuals based on your saw's serial number. They have a troubleshooting guide in the manual that may be a good place to start. Good luck. lawson56 and OCtoolguy 2 Quote
Dan Posted December 26, 2022 Report Posted December 26, 2022 Oh...and welcome to the Village! lawson56 and OCtoolguy 2 Quote
OCtoolguy Posted December 26, 2022 Report Posted December 26, 2022 There were some vintages of saws that had motor issues. But first, with power off try to get he motor to rotate. It might just be on a bad spot on the armature. See if there is a hole in the end of the motor where you can insert a flat-blade screwdriver to turn the armature. If not try to move the crankshaft and get it to rotate. If your saw has variable speed control that could also be a problem but can be repaired. Good luck. Let us know what you find and welcome to the Village! Quote
BadBob Posted December 27, 2022 Report Posted December 27, 2022 I had to replace the switch on mine. OCtoolguy 1 Quote
kmmcrafts Posted December 28, 2022 Report Posted December 28, 2022 My first Hawk did the same thing.. but worked fine for 4 years after and probably still working for the new owner.. I just took the cover off the control box and blew some compressed air around.. there was a fair amount of dust that made its way inside that box on mine.. might try that.. OCtoolguy 1 Quote
