Wichman Posted January 2, 2023 Report Posted January 2, 2023 While researching for the bolts to secure the Hegner to the brackets for the Miter saw stand, I ran across a short note in the Hegner Manual that discussed the size of blade to the blade holders. There are three sizes of blade holders for the Hegner; .5mm (blades, #4 and smaller), .7mm ( #4 though #9 ) and 1.0mm ( larger than #9 ). Using too large a holder may result in premature failure at the clamp. .7 mm is the standard size that ships with the Hegner. I use mostly smaller than #4 blades and I had been having issues lately braking more blades than normal. I have ordered new blade holders; two sets of .5mm and one set of 1.0mm. I'll update after I've had a chance to try them out. OCtoolguy, Dan, stoney and 1 other 4 Quote
Dave Monk Posted January 3, 2023 Report Posted January 3, 2023 All I ever use is the small one. OCtoolguy 1 Quote
starman Posted January 8, 2023 Report Posted January 8, 2023 I always match the clamp to the blade size, as you listed. However it is my experience that I break more blades (usually Pegas mg) with my Hegner than my Excalibur. The clamps are fantastic, but many breaks occur at the jaw of the clamp. I usually eject the 1/8 inch piece in the jaw and reclamp and retension the remaining blade. I also loosen the top screw about a quarter turn to allow the blade assembly more freedom of movement, but breaks still can occur. OCtoolguy 1 Quote
Wichman Posted January 13, 2023 Author Report Posted January 13, 2023 (edited) Update I received the new clamps last week and the blade breakage is way down. This should make scrolling even more fun. Edited January 13, 2023 by Wichman OCtoolguy, Dak0ta52, NC Scroller and 1 other 4 Quote
