Popular Post Denny Knappen Posted January 9, 2023 Popular Post Report Posted January 9, 2023 A finished Alex Fox basket pattern C03 enlarged 30%. I used 1/4" Baltic Birch plywood 10" square. Cut on the Pegas Scroll Saw using Pegas #1 MGT blades. After sanding with a Mac Mop, I glued each ring and waited for the glue to dry, so the glue up took time. The finish is spray Lacquer Clear Gloss. Comments welcome. namunolie, barb.j.enders, jollyred and 10 others 13 Quote
Dak0ta52 Posted January 9, 2023 Report Posted January 9, 2023 Very nice bowl, Denny. I'm sure cutting took some time also. Thirteen layers plus the bottom. But your time and effort paid off with beautiful results. Quote
Denny Knappen Posted January 9, 2023 Author Report Posted January 9, 2023 10 minutes ago, Dak0ta52 said: Very nice bowl, Denny. I'm sure cutting took some time also. Thirteen layers plus the bottom. But your time and effort paid off with beautiful results. Thanks Rodney. After finishing this one, turned into my favorite Alex Fox Basket pattern Quote
Denny Knappen Posted January 10, 2023 Author Report Posted January 10, 2023 1 hour ago, Ron Johnson said: Very beautiful Denny Thank you, Ron. Quote
scrollerpete Posted January 10, 2023 Report Posted January 10, 2023 Denny another fine project you must have the patience of an angel regarding the to glue it together Quote
Denny Knappen Posted January 10, 2023 Author Report Posted January 10, 2023 13 hours ago, rjweb said: Another beautiful piece Denny, RJ Thanks RJ. Quote
Denny Knappen Posted January 10, 2023 Author Report Posted January 10, 2023 6 hours ago, namunolie said: Beautiful work ! Thanks. Maybe back to puzzles. Quote
Denny Knappen Posted January 10, 2023 Author Report Posted January 10, 2023 3 hours ago, daveww1 said: fantastic job, it's beautiful Thanks Dave. Quote
Denny Knappen Posted January 10, 2023 Author Report Posted January 10, 2023 2 hours ago, scrollerpete said: Denny another fine project you must have the patience of an angel regarding the to glue it together Thanks Pete. One ring in the morning, then off to ArtCrafters and then one ring at night. Quote
don watson Posted January 11, 2023 Report Posted January 11, 2023 Well done with that bowl. I think it is the simplest of his designs and goes together really well if you take a little care. I use mine to hold sweets and visitors love it. You have a nice finish on it as well. I don't usually give mine a spray coat to finish. Very nicely done. Quote
alexfox Posted January 11, 2023 Report Posted January 11, 2023 Just now, don watson said: Well done with that bowl. I think it is the simplest of his designs and goes together really well if you take a little care. I use mine to hold sweets and visitors love it. You have a nice finish on it as well. I don't usually give mine a spray coat to finish. Very nicely done. I agree, it is the simplest one, but 13 layers make such great looking effect. Some scrollers dont cut all pieces, I understand that smallest pieces are most difficult, but more layers - better effect. Nice cutting. don watson 1 Quote
Denny Knappen Posted January 11, 2023 Author Report Posted January 11, 2023 3 hours ago, don watson said: Well done with that bowl. I think it is the simplest of his designs and goes together really well if you take a little care. I use mine to hold sweets and visitors love it. You have a nice finish on it as well. I don't usually give mine a spray coat to finish. Very nicely done. Thanks for the nice comments. These are fun to make. don watson 1 Quote
Rolf Posted January 11, 2023 Report Posted January 11, 2023 Denny, great job as usual! Alex has some amazing designs and I have cut a few of them. The biggest challenge to me is the assembly. I have a tendency is to skew to one side. I built myself an alignment jig with a turntable. Also glue squeeze out. Quote
rdatelle Posted January 11, 2023 Report Posted January 11, 2023 Nice job on that one Denny, Looks like a lo of cutting. Quote
don watson Posted January 13, 2023 Report Posted January 13, 2023 My biggest problem is finding the best/correct materials to cut them from. I have problems getting 1/4" (5 - 6 mm) plywood and wondered if mdf was a substitute ?? but I don't really like using mdf. Quote
Denny Knappen Posted January 13, 2023 Author Report Posted January 13, 2023 On 1/11/2023 at 9:38 AM, Rolf said: Denny, great job as usual! Alex has some amazing designs and I have cut a few of them. The biggest challenge to me is the assembly. I have a tendency is to skew to one side. I built myself an alignment jig with a turntable. Also glue squeeze out. Thanks Rolf. I saw your jig on the other forum, but I line up by sight. Glue squeeze out is always a problem. Quote
Denny Knappen Posted January 13, 2023 Author Report Posted January 13, 2023 On 1/11/2023 at 10:20 AM, rdatelle said: Nice job on that one Denny, Looks like a lo of cutting. Thanks ralph. The cutting didn't take long, just an afternoon at ArtCrafters. Cutting along with doing lots of other things. Quote
Denny Knappen Posted January 13, 2023 Author Report Posted January 13, 2023 1 hour ago, don watson said: My biggest problem is finding the best/correct materials to cut them from. I have problems getting 1/4" (5 - 6 mm) plywood and wondered if mdf was a substitute ?? but I don't really like using mdf. I used plywood because of the strength it provides. I don't think mdf will give the strength needed. don watson 1 Quote
don watson Posted January 14, 2023 Report Posted January 14, 2023 Thanks Denny. I will stick with plywood when I can get some. Quote
bobscroll Posted January 14, 2023 Report Posted January 14, 2023 I love it! You did a great job on the basket Denny! Thank you for letting us see, Bob Quote
Rolf Posted January 14, 2023 Report Posted January 14, 2023 (edited) I inherited a professional solder/ glue dispenser when a hearing aid amp manufacturer I worked for went under. It is a pneumatic syringe dispenser. It allows you to control the amount of glue dispensed and has controllable suckback No drips! The unit was very! expensive back then. It is a EFD 1000 XL probably cost the company close to $2000. They still want crazy money for a refurbished unit, I just found a clone on Amazon that looks exactly like it. It is foot pedal controlled and can be set to continuous or timed dispense. I just have to find a reasonable source for the syringes. Here is a video of a different dispenser that shows what one of these can do. https://www.amazon.com/Dispenser-Controller-Adhesive-Semi-Automatic-Operations/dp/B07QVBMWZL/ref=asc_df_B07QVBMWZL/?tag=hyprod-20&linkCode=df0&hvadid=366352853698&hvpos=&hvnetw=g&hvrand=11461732102490602969&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004484&hvtargid=pla-795729708142&psc=1&tag=&ref=&adgrpid=76503872856&hvpone=&hvptwo=&hvadid=366352853698&hvpos=&hvnetw=g&hvrand=11461732102490602969&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004484&hvtargid=pla-795729708142 Edited January 14, 2023 by Rolf Quote
