Badgerboy Posted January 13, 2023 Report Posted January 13, 2023 I am curious if anyone has ever stack cut a sizeable portrait. I need to cut 3 portraits for family out of 1/4 ply. The size is about 8x10. It has a moderate amount of fine detail and I would like to optimize and at the very least stack two of the three to eliminate 3 individual cuttings. I stack cut ornaments and other smaller items often but am wondering if the larger more complex design will really cut well in a stack. I would love to hear some thoughts from those of you who may have wandered down this road. Thanks. OCtoolguy and don watson 2 Quote
redwine Posted January 13, 2023 Report Posted January 13, 2023 (edited) Actually you will be doing yourself a great service by stack cutting anything you need 2 or more of! Stack cutting portraits is one item that benefits as if you make a slight mistake or go off line slightly, the other cuttings will be the same and if and I say if, someone happens to see the mistake and questions you about it, just tell them that was the way the pattern was! Any time you have more than one to cut ,by all means stack cut! In your case you can very easily cut all 3 at the same time. One caution, be sure your blade is at right angle to the table before cutting! Erv Edited January 13, 2023 by redwine don watson, LarryEA, danny and 2 others 4 1 Quote
Scrappile Posted January 13, 2023 Report Posted January 13, 2023 I have stack cut many detailed pictures and portraits, but my limit is 3- 1/8" layers. That is just my preference. If you are comfortable cutting 3-1/4" why would you not? danny, Dan and OCtoolguy 2 1 Quote
Bill WIlson Posted January 13, 2023 Report Posted January 13, 2023 Stacking 3 layers of 1/4" material may present its own challenges. Personally, I would probably opt for 1/8" ply if I knew I wanted 3 pieces. but yes, stack cut multiples whenever feasible. don watson, Roberta Moreton, Dave Monk and 2 others 5 Quote
Roberta Moreton Posted January 13, 2023 Report Posted January 13, 2023 Are you putting a backer on them? Wouldn’t that make them 1/8” cut, 1/8” backer, I/4” finished product? danny, don watson and OCtoolguy 3 Quote
kmmcrafts Posted January 13, 2023 Report Posted January 13, 2023 I almost always stack cut portraits.. many of mine are 11 x 14 inch and I never used 1/4" for portraits.. since I don't make my own frames I find it hard to get anything in them more than 1/4" and I always use a backer so 1/8 + a backer is usually very close to 1/4.. and even then sometimes hard to find a frame unless I take the glass out, LOL. I typically stack 4 at a time but sometimes will do 5-6.. or sometimes only 3.. never wasted time on anything less than three.. OCtoolguy, don watson and danny 3 Quote
Clayton717 Posted January 14, 2023 Report Posted January 14, 2023 I always stack cut my portraits. Usually 3 at a time buti use 1/8" Baltic birch. I have cut some as big as 16x20. don watson, OCtoolguy and danny 3 Quote
Dak0ta52 Posted January 14, 2023 Report Posted January 14, 2023 Everything I cut is stack cut using 1/4-inch ply. I only stack cut 2 pieces. I've found stacking 3 poses a bit of a problem with the deviation of the blade when pressing through a cut. If you do stack cut three, you have to slow your cuts and let the blade "catch up" especially on sharper turns. The largest I've stack cut is 14X21 and I didn't have any problems, even on my 16-inch saw. I typically use spiral blades and tend to use a smaller blade than typical. (between 2/0 and 1) Like Clayton said, if you used 1/8 ply, you could probably get away with triple stack without any problems. Good luck. don watson, OCtoolguy and danny 3 Quote
TAIrving Posted January 14, 2023 Report Posted January 14, 2023 Lots of good advice already. In addition, ensure that the layers are securely attached so there is no movement between layers while cutting. With fine detail in the pattern, any shifting during cutting means that the lower layers will be unusable. Don't ask how I know this. danny and OCtoolguy 2 Quote
William Eicehelberger Posted January 14, 2023 Report Posted January 14, 2023 On any project that I will use 2 or more copies I cut 3 I make my own frames so the size doesn't matter. My backers is usually some scrap ply found in the dumpster With the price of balletic birch I don't make many prostrates or pictures The ;main thing is that the blade is square with the table Bill OCtoolguy and danny 2 Quote
Badgerboy Posted January 14, 2023 Author Report Posted January 14, 2023 Thanks for your shared wisdom. I use 1/4 on portraits as I like the visual depth against the backer, just a personal preference. OCtoolguy 1 Quote
