Denny Knappen Posted January 16, 2023 Report Posted January 16, 2023 A finished basket. The pattern #C-09 is by Alex Fox. I enlarged the pattern by 30% and used 1/4" Baltic Birch plywood 10" square. Cut on the Pegas scroll saw using Pegas #1R MGT blades. After gluing and sanding, the finish is one coat spray Shellac, another sanding and a final coat of spray Lacquer Clear Gloss. Comments welcome. Scrappile, RabidAlien, Charlie E and 4 others 7 Quote
Denny Knappen Posted January 16, 2023 Author Report Posted January 16, 2023 49 minutes ago, Scrappile said: Nice job, Denny! Thank Paul. A little difficult to line up. Quote
rjweb Posted January 16, 2023 Report Posted January 16, 2023 Very nice Denny, I guess we will have to call you the basket man, RJ Quote
Denny Knappen Posted January 16, 2023 Author Report Posted January 16, 2023 2 minutes ago, rjweb said: Very nice Denny, I guess we will have to call you the basket man, RJ Thanks RJ. Just not a basket case! Quote
flarud Posted January 16, 2023 Report Posted January 16, 2023 Awesome indeed! Tedious sanding I'm sure. Quote
Denny Knappen Posted January 16, 2023 Author Report Posted January 16, 2023 1 hour ago, flarud said: Awesome indeed! Tedious sanding I'm sure. Thanks. Sanding not bad using a Mac Mop. Quote
Dak0ta52 Posted January 17, 2023 Report Posted January 17, 2023 You've definitely mastered the bowls, Denny. Another great job. Quote
scrollerpete Posted January 17, 2023 Report Posted January 17, 2023 Well you are getting very good at making these bowls, very impressive Quote
Denny Knappen Posted January 17, 2023 Author Report Posted January 17, 2023 18 hours ago, Farmerdon said: Looks great Denny. Thank you Quote
Denny Knappen Posted January 17, 2023 Author Report Posted January 17, 2023 12 hours ago, Dak0ta52 said: You've definitely mastered the bowls, Denny. Another great job. Thank you Rodney. Quote
Denny Knappen Posted January 17, 2023 Author Report Posted January 17, 2023 2 hours ago, daveww1 said: awesome job Thank you Dave Quote
Denny Knappen Posted January 17, 2023 Author Report Posted January 17, 2023 2 hours ago, scrollerpete said: Well you are getting very good at making these bowls, very impressive Thanks Pete. Quote
