Popular Post Tbow388 Posted February 25, 2023 Popular Post Report Posted February 25, 2023 Just some of the new bowls. I was pretty happy with them all. Phantom Scroller, Charlie E, goldfish and 7 others 10 Quote
Dak0ta52 Posted February 26, 2023 Report Posted February 26, 2023 Wow. They turned out great. Is the first bowl made out of plywood? If so, where do you get plywood without voids? Tbow388 1 Quote
wombatie Posted February 26, 2023 Report Posted February 26, 2023 You are now the master of bowls. They are all excellent. Marg Tbow388 1 Quote
preprius Posted February 26, 2023 Report Posted February 26, 2023 n i i i i c e. I like the kidney bean shape. Tbow388 1 Quote
Tbow388 Posted February 26, 2023 Author Report Posted February 26, 2023 8 hours ago, Dak0ta52 said: Wow. They turned out great. Is the first bowl made out of plywood? If so, where do you get plywood without voids? The butcher block one is 1" (actual) thick Maple butcher block countertop. If you can imagine several hundred 1 inch pieces being glued up together sideways. I took the piece that I had (4"x18"), planed it down to 3/4 cut 4" sections glued them together opposing and then cut away. Dak0ta52 1 Quote
Tbow388 Posted February 26, 2023 Author Report Posted February 26, 2023 8 hours ago, wombatie said: You are now the master of bowls. They are all excellent. Marg Thanks Marg, I am the master of not being able to sit still so I go to the shop. wombatie 1 Quote
Tbow388 Posted February 26, 2023 Author Report Posted February 26, 2023 4 hours ago, preprius said: n i i i i c e. I like the kidney bean shape. Thanks a million. That was a fun project. It all started with one random kidney shaped cut. will definetly be a one of a kind. Quote
Scrollshrimp Posted February 26, 2023 Report Posted February 26, 2023 Very nice, I wish I could get my bowls to turn out as good. Always seem to struggle with the angle for the thickness of wood I'm cutting. Tbow388 and barb.j.enders 1 1 Quote
Gonzo Posted February 26, 2023 Report Posted February 26, 2023 I too like the kidney bowl. two questions. what angle are you using? do you drill a hole at the same angle to start your cut? Or do you enter from the side and glue each piece back together? ok so that was three questions.. Oops Tbow388 1 Quote
Charlie E Posted February 26, 2023 Report Posted February 26, 2023 I've got to give this a try one day. You've created some beautiful bowls/art! Tbow388 1 Quote
Tbow388 Posted February 27, 2023 Author Report Posted February 27, 2023 (edited) 10 hours ago, Gonzo said: I too like the kidney bowl. two questions. what angle are you using? do you drill a hole at the same angle to start your cut? Or do you enter from the side and glue each piece back together? ok so that was three questions.. Oops Gonzo The angle depends on the thickness of the wood And the thickness of the ring. I use a digital caliper and construction calculator to figure out the angle for each individual bowl. I then drill a hole at the same angle using a 3/64 drill bit. If you don’t have those things then there are some videos on YouTube I think. Edited February 27, 2023 by Tbow388 Gonzo 1 Quote
Tbow388 Posted February 27, 2023 Author Report Posted February 27, 2023 13 hours ago, Gonzo said: I too like the kidney bowl. two questions. what angle are you using? do you drill a hole at the same angle to start your cut? Or do you enter from the side and glue each piece back together? ok so that was three questions.. Oops Gonzo I was thinking on the best way to explain it. If you have a 3/4 thick piece of wood and the rings on the bowl pattern are 1/4 thick. you would make 2 lines on the side of your 3/4 board 1/4 inch apart. Set your saws agle to go diagonal between those two lines. Then you cut a small piece of and use a drill press to drill at the same angle or use the pieces that you cut off as a guide to hand drill your angle. Does that make any sense? If not I will photo the process and post it on here. Quote
Peter N White Posted February 27, 2023 Report Posted February 27, 2023 Very good bowls a photo would be help. Tbow388 1 Quote
Ron Johnson Posted February 27, 2023 Report Posted February 27, 2023 And you should be Timothy. They’re all beautiful Tbow388 1 Quote
Tbow388 Posted February 27, 2023 Author Report Posted February 27, 2023 Here are the photos of how I used to do it before my brother helped me be technical. Quote
Tbow388 Posted February 27, 2023 Author Report Posted February 27, 2023 Here is a more technical version, adding some shiny tools that I have acquired. Gene Howe 1 Quote
Tbow388 Posted February 27, 2023 Author Report Posted February 27, 2023 Here is a thread that I started. Quote
Peter N White Posted February 27, 2023 Report Posted February 27, 2023 Thankyou for photos they help. Quote
Tbow388 Posted February 28, 2023 Author Report Posted February 28, 2023 1 hour ago, Gonzo said: Thank you Tbow! Does this give you a better idea? Quote
Gonzo Posted February 28, 2023 Report Posted February 28, 2023 Yes, very much so. Thank you! Tbow388 1 Quote
scrollerpete Posted February 28, 2023 Report Posted February 28, 2023 There is a free software that you can also use, it is call scrollmania.com Tbow388 1 Quote
Phantom Scroller Posted March 1, 2023 Report Posted March 1, 2023 Splendid looking bowls like the idea of the block to get the drill angle I usually guess mine. Roly Tbow388 1 Quote
