flarud Posted March 5, 2023 Report Posted March 5, 2023 Since my shop remodel I assembled and am using the factory Dewalt stand. It works ok but I have to move it on occasion and it probably shouldn't be dragged around like I am doing. Has anyone put wheels on the factory stand? Does the stand/saw stay in place while using it or does it move around a bit? I have recently used a couple different wheels for recent projects that had the option for wheel locks, which I purchased and they work. But those applications do not have a running saw with vibrations,, not sure how good locking wheels would work. I am trying to avoid having to build my own heavy duty stand with wheels at this point. Any input would be appreciated. Thanks, Barry scrollingforsanity and OCtoolguy 2 Quote
OCtoolguy Posted March 5, 2023 Report Posted March 5, 2023 How about putting wheels on just two of the legs and mounting them so that they only slightly touch the floor? When moving is necessary you'd just lift one end and roll it around. tomsteve, ChelCass, scrollingforsanity and 1 other 4 Quote
flarud Posted March 5, 2023 Author Report Posted March 5, 2023 2 minutes ago, OCtoolguy said: How about putting wheels on just two of the legs and mounting them so that they only slightly touch the floor? When moving is necessary you'd just lift one end and roll it around. Genius! LOL I could see the problem with that possibly is the stock stand has one leg in the back and two on the front. I think wheels on the front two would work best but with my set-up, it's not easy to get to the back of the saw. I will play around with your idea though. I thought about the wheels that lift up when not in use allowing the stands feet to be planted on the floor but those are pricey and probably too big,, unless they come in smaller sizes. (I only remember them in one size) scrollingforsanity and OCtoolguy 2 Quote
OCtoolguy Posted March 5, 2023 Report Posted March 5, 2023 2 minutes ago, flarud said: Genius! LOL I could see the problem with that possibly is the stock stand has one leg in the back and two on the front. I think wheels on the front two would work best but with my set-up, it's not easy to get to the back of the saw. I will play around with your idea though. I thought about the wheels that lift up when not in use allowing the stands feet to be planted on the floor but those are pricey and probably too big,, unless they come in smaller sizes. (I only remember them in one size) Ok, how about building a cradle for the rear leg that spreads the footprint out maybe the same width as the 2 front legs and recess the two wheels? scrollingforsanity 1 Quote
kmmcrafts Posted March 5, 2023 Report Posted March 5, 2023 I have these on the "big equipment" bandsaw etc. they work great.. when needing moved you flip the lever and it raises / lowers so the wheels are on the ground and then you can park it and it sets up off the wheels. This is kind of pricey but you could easily build something out of wood for a scroll saw.. I think Harbor Freight has something similar too but much cheaper.. I don't think you're going to want the wheels permanently fixed to the ground because I think it'll cause some vibration unless you have a perfect level floor and so far in my life I've never seen one that is perfect.. https://www.grizzly.com/products/grizzly-bear-crawl-heavy-duty-mobile-base/t28000 scrollingforsanity and OCtoolguy 2 Quote
OCtoolguy Posted March 5, 2023 Report Posted March 5, 2023 1 hour ago, kmmcrafts said: I have these on the "big equipment" bandsaw etc. they work great.. when needing moved you flip the lever and it raises / lowers so the wheels are on the ground and then you can park it and it sets up off the wheels. This is kind of pricey but you could easily build something out of wood for a scroll saw.. I think Harbor Freight has something similar too but much cheaper.. I don't think you're going to want the wheels permanently fixed to the ground because I think it'll cause some vibration unless you have a perfect level floor and so far in my life I've never seen one that is perfect.. https://www.grizzly.com/products/grizzly-bear-crawl-heavy-duty-mobile-base/t28000 I've used these a couple of times. They work well. The cost does keep going up though. scrollingforsanity and kmmcrafts 2 Quote
kmmcrafts Posted March 5, 2023 Report Posted March 5, 2023 36 minutes ago, OCtoolguy said: I've used these a couple of times. They work well. The cost does keep going up though. Still a lot cheaper than the ones I bought years ago.. though I don't think HF had these at the time I bought mine. Can't remember the brand name on mine now but very well made and been very happy with them so far. OCtoolguy and scrollingforsanity 2 Quote
OCtoolguy Posted March 5, 2023 Report Posted March 5, 2023 Just now, kmmcrafts said: Still a lot cheaper than the ones I bought years ago.. though I don't think HF had these at the time I bought mine. Can't remember the brand name on mine now but very well made and been very happy with them so far. I'll bet yours are HTC. They were the best at one time but very pricey. I think Delta sold them under their name. scrollingforsanity 1 Quote
BadBob Posted March 6, 2023 Report Posted March 6, 2023 I have four double-locking casters on both of my saws. I have never needed to lock them. OCtoolguy 1 Quote
Freddie Posted March 7, 2023 Report Posted March 7, 2023 I bought a “Wen” adjustable mobile base with two fixed wheels and two swivel wheels that also has a locking mechanism. I cut a piece of plywood to fit the interior of the base and then mounted my Dewalt stand to the plywood. The two swivel wheels are on a lever that you use to either lock it down to work or move it. Works great. You can get at Lowe’s or Amazon for less than $60. I don’t know how to paste link to the site or I would have. OCtoolguy 1 Quote
Norm Fengstad Posted March 7, 2023 Report Posted March 7, 2023 I have my saw on castors , makes it nice to move especially for the summer sunshine days. Might be a bit more vibration and some times it moves when I don't want t to but these are easily resolved nuesances OCtoolguy 1 Quote
OCtoolguy Posted March 7, 2023 Report Posted March 7, 2023 2 hours ago, Norm Fengstad said: I have my saw on castors , makes it nice to move especially for the summer sunshine days. Might be a bit more vibration and some times it moves when I don't want t to but these are easily resolved nuesances Set it on a piece if fatigue mat and solve both. flarud 1 Quote
flarud Posted March 13, 2023 Author Report Posted March 13, 2023 Thanks to everyone and all of the ideas. I ended up going with a set of Bora wheels. They work perfect. When I need to use the bandsaw, I can pull the scrollsaw out of the way. When finished, I can back it right back into place. OCtoolguy 1 Quote
CharleyL Posted March 14, 2023 Report Posted March 14, 2023 The usual scroll saw stands are 3 legs, making many of the add-on wheel systems not really work well. I once tried wheels on my scroll saw stand and took them off a week later. The saw kept moving while I was using it. I ended up putting pinball machine feet on my scroll saws. They stay in place, but when you want to move the saw, they will slide easily on relatively smooth floors, and I've found them to be perfect for the need. I use them on my table saw extensions, as well as several other tool stands in my shop. The Pinball Resource is the best and cheapest place to get them. I think that once you see the photo that I have attached, you will readily see how easy it is to add these to most scroll saw stands by adding a few fender washers and nuts from your nearby hardware store. The one that you want will most likely be part # Leg3T. The bolt-to-head connection is loose but secure, to allow the head to slip easily over small bumps and seams in the floor. Add a couple of fender washers and a second nut to these and they will fit most metal legged stands with the hole in the bottom plate. At $1.10 each, I don't think you will find a better deal anywhere for any kind of feet for your scroll saws. Though Steve (the owner) is a friend of mine. I have no financial interest in your business with him. http://www.pbresource.com/cabparts.html Look down the screen until you see the photo attached. There are several versions, but this seems to be the best for scroll saw use. LEG3 is the part number. Charley OCtoolguy 1 Quote
BadBob Posted March 15, 2023 Report Posted March 15, 2023 5 hours ago, CharleyL said: The usual scroll saw stands are 3 legs, making many of the add-on wheel systems not really work well. I once tried wheels on my scroll saw stand and took them off a week later. The saw kept moving while I was using it. I have owned three different saws, all with stands with four legs. My saws have four double-locking casters and they never move unless I push or pull on the saw. I have never locked the casters other than to test them.\ OCtoolguy 1 Quote
Norm Fengstad Posted March 15, 2023 Report Posted March 15, 2023 On 3/7/2023 at 11:44 AM, OCtoolguy said: Set it on a piece if fatigue mat and solve both. Thanks for the tip, I will give it a try OCtoolguy 1 Quote
new2woodwrk Posted March 15, 2023 Report Posted March 15, 2023 (edited) Every stand I've made for my shop is on wheels including the scroll stand! I use 4 lockable wheels on all the stands. Makes my shop very flexible! Edited March 15, 2023 by new2woodwrk BadBob and OCtoolguy 2 Quote
rash_powder Posted March 18, 2023 Report Posted March 18, 2023 I've got 4 casters mounted to the bottom of my stand. It rolls wonderfully, and when I want it 'parked' I stand a 2x4 on edge in the middle of the back. It lifts the stand just enough to not roll and gives an extra wee bit of table tilt toward me. BadBob and OCtoolguy 2 Quote
Joe W. Posted March 19, 2023 Report Posted March 19, 2023 I have retractable casters on my scroll saw stands and a newly made bench for my table top router. They have worked well for me in the garage. https://www.amazon.com/SPACEKEEPER-Workbench-Caster-kit-Retractable/dp/B07QRH8VS2/ref=asc_df_B07QRH8VS2/?tag=hyprod-20&linkCode=df0&hvadid=365913144387&hvpos=&hvnetw=g&hvrand=16440853423039295243&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1014906&hvtargid=pla-810822295110&psc=1&tag=&ref=&adgrpid=74513983885&hvpone=&hvptwo=&hvadid=365913144387&hvpos=&hvnetw=g&hvrand=16440853423039295243&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1014906&hvtargid=pla-810822295110 OCtoolguy 1 Quote
btseed357 Posted September 22, 2024 Report Posted September 22, 2024 On 3/13/2023 at 1:37 PM, flarud said: Thanks to everyone and all of the ideas. I ended up going with a set of Bora wheels. They work perfect. When I need to use the bandsaw, I can pull the scrollsaw out of the way. When finished, I can back it right back into place. Since its been about 1 1/2 years since you added the Bora wheels and ample time to use them, have you had any issues with vibration or stability or anything else? I am considering ordering some to put on my stand as well. Thanks in advance. OCtoolguy 1 Quote
flarud Posted September 22, 2024 Author Report Posted September 22, 2024 5 hours ago, btseed357 said: Since its been about 1 1/2 years since you added the Bora wheels and ample time to use them, have you had any issues with vibration or stability or anything else? I am considering ordering some to put on my stand as well. Thanks in advance. There was a little vibration. I put a concrete block on the lower shelf of the factory stand and the vibration went away. Any kind of weight would work. I'm glad I went with the Bora wheel kit. btseed357 1 Quote
