MarieC Posted March 7, 2023 Report Posted March 7, 2023 I cannot figure out a good lighting system. I do not have astigmatism but it sure feels that way. Does anyone recommend a good lighting system so that doesn't happen. I have an Excaliber 21. Thanks so much ahead of time. scrollingforsanity and OCtoolguy 1 1 Quote
Scrappile Posted March 7, 2023 Report Posted March 7, 2023 Many use these, I have one and I also have a more expensive one that has glass lens and LED light. Some people are bothered by fluorescent lighting. I use both all the time, one on my saw and one attached to my work bench. I do like the glass lens a little better, sometimes the LED light seems a little too bright, depending on what I am working on. https://www.harborfreight.com/fluorescent-magnifying-lamp-60643.html?_br_psugg_q=magnifying+lamp scrollingforsanity and OCtoolguy 2 Quote
Sycamore67 Posted March 7, 2023 Report Posted March 7, 2023 I have an Ottlite which is not attached to my saw. I have no such issues MarieC, scrollingforsanity and OCtoolguy 2 1 Quote
Denny Knappen Posted March 7, 2023 Report Posted March 7, 2023 I have two on my website. I use the fluorescent all the time and even with astigmatism, no problems. OCtoolguy and scrollingforsanity 2 Quote
MarieC Posted March 8, 2023 Author Report Posted March 8, 2023 3 hours ago, Sycamore67 said: I have an Ottlite which is not attached to my saw. I have no such issues I will check that one out as well as... Thank you! OCtoolguy 1 Quote
MarieC Posted March 8, 2023 Author Report Posted March 8, 2023 I will check out your website....Thank you! OCtoolguy 1 Quote
BadBob Posted March 8, 2023 Report Posted March 8, 2023 I use sewing machine lights on my EX21. They are cheap and they work great. https://www.amazon.com/gp/product/B07N1MK51J/ ChelCass and OCtoolguy 2 Quote
barb.j.enders Posted March 8, 2023 Report Posted March 8, 2023 I have the DeWalt light fixture that I have put an LED bulb in. I also have a 4' LED shop light over head. OCtoolguy 1 Quote
TAIrving Posted March 8, 2023 Report Posted March 8, 2023 16 hours ago, Sycamore67 said: I have an Ottlite which is not attached to my saw. I have no such issues I also have an Ottlite and am pleased with it. The LED lights put out a strong, white light and the magnifying lens is just right for me at my scroll saw. I sometimes move it around the shop to my drill press and other machines. OCtoolguy 1 Quote
Denny Knappen Posted March 8, 2023 Report Posted March 8, 2023 14 hours ago, MarieC said: I will check out your website....Thank you! The cover photo shows the setup with the light attacked to the saw. OCtoolguy and MarieC 1 1 Quote
MarieC Posted March 8, 2023 Author Report Posted March 8, 2023 3 hours ago, BadBob said: I use sewing machine lights on my EX21. They are cheap and they work great. https://www.amazon.com/gp/product/B07N1MK51J/ I like those as well because you have light coming from both sides. I do like the idea of a magnifier though. Tough decisions. Since I do upholstery I think I will look into these since I could use them on my sewing machines (which could use more light) if they don't work out for my saw. I like that they are magnetic as well. Thank you! OCtoolguy 1 Quote
MarieC Posted March 8, 2023 Author Report Posted March 8, 2023 1 hour ago, TAIrving said: I also have an Ottlite and am pleased with it. The LED lights put out a strong, white light and the magnifying lens is just right for me at my scroll saw. I sometimes move it around the shop to my drill press and other machines. 18 hours ago, Sycamore67 said: I have an Ottlite which is not attached to my saw. I have no such issues When I did a google search I found a bunch of different Ottlites...could you provide me a link or a picture of what yours is. Thank you! OCtoolguy 1 Quote
MarieC Posted March 8, 2023 Author Report Posted March 8, 2023 39 minutes ago, Denny Knappen said: The cover photo shows the setup with the light attacked to the saw. Do you know how many lumins your LED one puts out? Is the flourescent one brighter? Thanks OCtoolguy 1 Quote
BadBob Posted March 8, 2023 Report Posted March 8, 2023 53 minutes ago, MarieC said: I like that they are magnetic as well. They come with a steel circle with 3M adhesive on the back, so you can mount them to plastic or aluminum if you like. OCtoolguy and MarieC 2 Quote
Denny Knappen Posted March 8, 2023 Report Posted March 8, 2023 1 hour ago, MarieC said: Do you know how many lumins your LED one puts out? Is the flourescent one brighter? Thanks The fluorescent uses a 22 W bulb. There is nothing on the LED box. MarieC and OCtoolguy 1 1 Quote
BadBob Posted March 8, 2023 Report Posted March 8, 2023 4 hours ago, Denny Knappen said: The fluorescent uses a 22 W bulb. There is nothing on the LED box. Watts is how much power it uses. Lumens measure the amount of brightness. OCtoolguy 1 Quote
jpburcham Posted March 8, 2023 Report Posted March 8, 2023 Not exact, but this may help with the watts to lumens conversion. OCtoolguy and MarieC 2 Quote
MarieC Posted March 9, 2023 Author Report Posted March 9, 2023 On 3/7/2023 at 9:22 AM, Scrappile said: Many use these, I have one and I also have a more expensive one that has glass lens and LED light. Some people are bothered by fluorescent lighting. I use both all the time, one on my saw and one attached to my work bench. I do like the glass lens a little better, sometimes the LED light seems a little too bright, depending on what I am working on. https://www.harborfreight.com/fluorescent-magnifying-lamp-60643.html?_br_psugg_q=magnifying+lamp Paul, what brand is your LED one? I would like a bright one. Fluorescent lighting can give me a headache after a while. I am still trying to figure out how bright Denny's is....but no luck...I will keep looking online. OCtoolguy 1 Quote
Lee0110 Posted March 9, 2023 Report Posted March 9, 2023 Use a glare filter: If your screen is reflecting too much light, consider using a glare filter. This can help reduce the amount of light bouncing off your screen and into your eyes. OCtoolguy 1 Quote
crupiea Posted March 9, 2023 Report Posted March 9, 2023 I have a cheap walmart floor lamp with a bright bulb and flexible neck next to my saw. Its not attached to the saw or table so doesnt vibrate or anything. Have a bright white bulb in it that I can see great with. OCtoolguy and MarieC 1 1 Quote
MarieC Posted March 9, 2023 Author Report Posted March 9, 2023 12 hours ago, Lee0110 said: Use a glare filter: If your screen is reflecting too much light, consider using a glare filter. This can help reduce the amount of light bouncing off your screen and into your eyes. Thank you....I don't have a screen of any type. I just use my safety glasses when I scroll saw. But a magnifier with a light might make my cutting better...gotta blame my mistakes on something OCtoolguy 1 Quote
OCtoolguy Posted March 10, 2023 Report Posted March 10, 2023 I started out with 4 2-bulb 40 watt flourescent overhead lights. Then H/F came out with their 5000 lumen LED lamps for $20 ea. I put four up in place of what I had. My little shop is so well lit now that sometimes I turn 2 if them off. I also have H/F lighted magnifiers mounted on the wall with LED replacement bulbs in them. I have NO problem seeing my work. If I make a mistake it's usually from loss of concentration. I DO like a lot of light. crupiea 1 Quote
Jim McDonald Posted March 10, 2023 Report Posted March 10, 2023 A few things to consider: White LED bulbs come in various colors ranging from reddish golden to a bright white resembling sunlight. It's called color temperature. The higher the number, the closer to sunlight (around 5500° K) Also, some LEDs are prone to strobing, especially the cheaper ones. This is largely due to voltage being dropped to the 5 to 12 volts the LED needs and also the cycling of AC power. The strobing is usually not visible to the naked eye as your visual center compensates, but it will give you eye strain. Quote
MarieC Posted March 10, 2023 Author Report Posted March 10, 2023 (edited) Forgot quote. see next reply Edited March 10, 2023 by MarieC Quote forgotten Quote
MarieC Posted March 10, 2023 Author Report Posted March 10, 2023 51 minutes ago, Jim McDonald said: A few things to consider: White LED bulbs come in various colors ranging from reddish golden to a bright white resembling sunlight. It's called color temperature. The higher the number, the closer to sunlight (around 5500° K) Also, some LEDs are prone to strobing, especially the cheaper ones. This is largely due to voltage being dropped to the 5 to 12 volts the LED needs and also the cycling of AC power. The strobing is usually not visible to the naked eye as your visual center compensates, but it will give you eye strain. Jim that is good info to know. Do you have a recommendation for an LED that is not the cheaper ones. I was thinking of getting one with a magnifier and that had glass. Any suggestions would be appreciated. Thanks so much. Quote
