I have found the needle files too coarse for my needs most of the time. Then a friend gave me a " bead reamer ", designed to enlarge the holes in small jewelry beads, these are smaller than needle files and much finer than typical needle files. Then I found bead reamers that are designed to be used in a Dremel tool.
https://www.amazon.com/10pc-Diamond-Reamer-Dremel-Rotary/dp/B018MNCZ4K?pd_rd_w=bE06y&content-id=amzn1.sym.deffa092-2e99-4e9f-b814-0d71c40b24af&pf_rd_p=deffa092-2e99-4e9f-b814-0d71c40b24af&pf_rd_r=EHFFXWZNR00FZ6B88YC0&pd_rd_wg=gUHoq&pd_rd_r=12880f64-d5b1-4b14-b0ba-b30f9717379e&pd_rd_i=B018MNCZ4K&psc=1&ref_=pd_bap_d_grid_rp_0_1_i
These things are great. one inch long taper, needle point to 1/16 inch wide at the top.
Interesting that someone used cloth backed sandpaper as I have not had good luck doing that.  Paper backed sandpaper worked better for me.
I have needle files that I use but will need to look at the diamond ones.
Part of the reason I started this thread is to find out what others are using.
