I dont use one (I use my photo editing programs for this) so, unfortunately, I can not answer this one for you, but I think rapid sizer (i think it is called) is used by a number of folks. Hopefully someone will come along that will have a good answer for you. If I may inquire, why do you want a resizer? Do you plan on cutting things larger than the patterns are set for or smaller?
But if you look in this section of the forums viewforum.php?f=19 you will find a few threads concerning this topic to some degree or another. Good luck.
Wayne....I use Rapid Resizer and it does work for enlarging and shrinking patterns. It works pretty well, but the quality loses something if you go up in size, quite a bit. I have used a marker to get the results I am after and it worked out well for me.....good luck..
  • 1 month later...
