Popular Post Denny Knappen Posted March 23, 2023 Popular Post Report Posted March 23, 2023 (edited) An Alex Fox Pattern C-03. I enlarged the pattern by 30% to fit 1/4" Baltic Birch plywood 10" square. Cut on the Pegas Scroll Saw using Pegas #1 MGT blades. Entry holes drilled with Grobet #68 HSS Twist Drill Bits. Finish is two coats spray Lacquer Clear Gloss with sanding on the Mac Mop between coats. Comments welcome. Edited March 23, 2023 by Denny Knappen Dan, Scrappile, rjweb and 9 others 12 Quote
Dak0ta52 Posted March 23, 2023 Report Posted March 23, 2023 Awesome piece, Denny. Just wondering, do you cut those on a 90-degree or do you give it some angle? And how in the world did you get a #1 blade to go through a #86 drill hole? You must have lubed it up first. Quote
Denny Knappen Posted March 23, 2023 Author Report Posted March 23, 2023 44 minutes ago, Dak0ta52 said: Awesome piece, Denny. Just wondering, do you cut those on a 90-degree or do you give it some angle? And how in the world did you get a #1 blade to go through a #86 drill hole? You must have lubed it up first. Ok Rodney. good eyes. The drill bits should be 68 not 86 Dak0ta52 1 Quote
FrankEV Posted March 24, 2023 Report Posted March 24, 2023 Very well done. I like it a lot. Wondering what Glue do you use? I guessing CA, if correct...Thick, Medium or Thin? And, do you glue every contact point on every ring? Quote
don watson Posted March 24, 2023 Report Posted March 24, 2023 Another good bowl nicely made. The glue ups are usually the sticky part (pardon the pun) with and I usually use the white glue or sometimes Titebond. Quote
Denny Knappen Posted March 24, 2023 Author Report Posted March 24, 2023 14 hours ago, FrankEV said: Very well done. I like it a lot. Wondering what Glue do you use? I guessing CA, if correct...Thick, Medium or Thin? And, do you glue every contact point on every ring? Thanks Frank. I use Titebond 11 and every other contact point. It is still very stable. FrankEV 1 Quote
Denny Knappen Posted March 24, 2023 Author Report Posted March 24, 2023 11 hours ago, wombatie said: Looks great Denny, well done. Marg Thanks Marg Quote
Denny Knappen Posted March 24, 2023 Author Report Posted March 24, 2023 8 hours ago, Peter N White said: Great looking bowl. Thanks Peter Quote
Denny Knappen Posted March 24, 2023 Author Report Posted March 24, 2023 7 hours ago, don watson said: Another good bowl nicely made. The glue ups are usually the sticky part (pardon the pun) with and I usually use the white glue or sometimes Titebond. Thanks Don. You are right about the sticky part. One ring at a time. Quote
Denny Knappen Posted March 24, 2023 Author Report Posted March 24, 2023 1 hour ago, rjweb said: Beautiful craftsmanship Denny, RJ Thanks RJ Quote
