Popular Post kmmcrafts Posted March 26, 2023 Popular Post Report Posted March 26, 2023 I posted this idea and it's progress in the Laser / CNC group here on the village but since there is only 15 members and also since I did use the scroll saw I figured it was okay to post here too.. This project started with rough cut walnut lumber and cutting / planing / jointing it down to do a glue up of a final size of 24W x 15H x 3/4.. Once glued and sanded I put 2-3 coats of Shellac and then sanded it down to 400 grit. I then covered the entire face with Oramask ( similar to shelf liner but way better ) I then used the CNC Router to carve out the text. After the carve I sealed the carved out portion with 3 coats of Lacquer and then hand painted the text with white acrylic paint and then peel off the oramask. Next I scroll saw the grill / utensils from 1/8" Maple and glued that onto the sign with weldbond glue. Next I laser engrave the Red Stag bottle on the laser from 1/8 BBply and straight off the laser top coated the engrave before anything smudges. Then I cut the bottle shape out on the scroll saw and also glue it to the sign. Once all was in place and dry I top coat with 3 coats of Lacquer.. I like these projects where I can incorporate each tool.. I hope to be doing many more projects like this. If you go the the "groups" section and find the CNC/Laser groups and join you can see the progress of this from the original carve design model through to the finished project. rjweb, MarieC, Dan and 14 others 17 Quote
rjweb Posted March 26, 2023 Report Posted March 26, 2023 Excellent craftsmanship Kevin, RJ kmmcrafts 1 Quote
Scrappile Posted March 26, 2023 Report Posted March 26, 2023 Really turned out nice. kmmcrafts 1 Quote
MarieC Posted March 26, 2023 Report Posted March 26, 2023 I like all the different depths. Reallly nice work. I too like using all my tools rather than seeing them gathering dust heppnerguy and kmmcrafts 1 1 Quote
wombatie Posted March 27, 2023 Report Posted March 27, 2023 It looks fabulous Kevin. Well done. Marg kmmcrafts 1 Quote
kmmcrafts Posted March 28, 2023 Author Report Posted March 28, 2023 Thanks for all the nice comments.. Quote
Phantom Scroller Posted March 28, 2023 Report Posted March 28, 2023 Good work Kev they look great. Roly kmmcrafts 1 Quote
heppnerguy Posted March 29, 2023 Report Posted March 29, 2023 that is a very nice sign project. I think you nailed it perfectly. Everything came out so well. One to be very proud of. Dick heppnerguy kmmcrafts 1 Quote
