Beeber Posted January 14, 2012 Report Posted January 14, 2012 I am making jig saw puzzels of animals. Notice that when I cut the piece lines that there is a lot of play between pieces. Can anyone recommend which blade to use to ensure a tighter fit? I use spiral blades for the cuts (size 5.) I would like very tight so when I sand, it leaves a little space for finishing. Quote
Clayton717 Posted January 14, 2012 Report Posted January 14, 2012 Try using an actual puzzle blade, or size 2/0 in a spiral may be close. Quote
FD Mike Posted January 14, 2012 Report Posted January 14, 2012 Hi Beeber, I would not use a spiral blade. Even a # 2/0 leaves a wide kerf. Besides you get nothing but round corners. Use a regular flat blade. The number depends on the thickness of the wood. FD Mike Quote
Beeber Posted January 14, 2012 Author Report Posted January 14, 2012 Hate to say this but I am ignorant in the use of plain blades. Have always used spiral, even for fine line work. Will try 2/0 but was not sure about thick wood. Thanks guys, will keep you informed. I am using Pine for softness. Quote
Terry Jay Posted January 15, 2012 Report Posted January 15, 2012 You said an animal jig saw puzzle. If you are cutting 1/4" or less, then a puzzle blade would be good. If you are cutting stand-up puzzles in 3/4" stock as suggested by saying you are using pine, then you may need a #1 or # 3 blade. I use a # 3, skip tooth and no reverse teeth. Quote
Beeber Posted January 16, 2012 Author Report Posted January 16, 2012 Thanks, ordering new different blades tomorrow. Will keep you up on what happens. Using 3/4 Pine. Quote
chippygeoff Posted January 17, 2012 Report Posted January 17, 2012 Hi Beeber. I make a lot of jigsaws to sell at craft fairs, mostly animals and not more than a dozen pieces in 3/4 hardwood. I use ultra reverse blades from Mikes workshop and usually it is a number 5 blade. With this blade it leaves a perfect finish so there is no need to sand the sides. I give the top and bottom of the wood a light sand prior to finishing. I tried making them in pine when I first started but getting a really good finish was the problem. Pine is okay if you are going to paint them but this is time consuming and the profits take a plunge. I find that people love to see the grain of the wood and feel it before buying. Quote
