kmmcrafts Posted March 31, 2023 Report Posted March 31, 2023 This should be the last of my walnut lumber. Hopefully I will be able to make room to get it all inside. Last two photos is what I had from last falls haul. I did use a small stack that I couldn’t get up above last year. Todays load has been cut for a year so it should be dry enough to use. I should be set on walnut lumber for a year or so I think. Now if he would just get some rejected cherry. The lumber graders will reject it if it’s not a certain length or if it has a split or knot in it within the certain length. crupiea, Dan, GrampaJim and 6 others 9 Quote
Dan Posted March 31, 2023 Report Posted March 31, 2023 When you run out of storage let me know. OCtoolguy 1 Quote
kmmcrafts Posted March 31, 2023 Author Report Posted March 31, 2023 43 minutes ago, Dan said: When you run out of storage let me know. How close are you and how much you want? I have way more walnut than I need. I’m only taking this stuff because it was headed to the burn pile or wood chipper. Lots of good crafts wood here. OCtoolguy 1 Quote
rjweb Posted March 31, 2023 Report Posted March 31, 2023 Kevin, good score, how do they say it you suck, LOL, RJ OCtoolguy and kmmcrafts 2 Quote
Scrappile Posted April 1, 2023 Report Posted April 1, 2023 THIS DEFINITELY DESIRES A "YOU SUCK, KEVIN"!!! All in fun. kmmcrafts, MarieC, OCtoolguy and 1 other 4 Quote
OCtoolguy Posted April 1, 2023 Report Posted April 1, 2023 Hey Kevin, YOU SUCK! kmmcrafts and MarieC 2 Quote
Dak0ta52 Posted April 1, 2023 Report Posted April 1, 2023 So Kevin, how much is shipping these days??? Another great score! Oh, and you suck! MarieC 1 Quote
Dan Posted April 1, 2023 Report Posted April 1, 2023 13 hours ago, kmmcrafts said: How close are you and how much you want? I have way more walnut than I need. I’m only taking this stuff because it was headed to the burn pile or wood chipper. Lots of good crafts wood here. Well Kevin, you are just a little further than I care to drive. Oh, you still suck. MarieC and kmmcrafts 2 Quote
kmmcrafts Posted April 1, 2023 Author Report Posted April 1, 2023 (edited) 1 hour ago, Dan said: Well Kevin, you are just a little further than I care to drive. Oh, you still suck. Well darn, I guess that means I need to unload the rest of the truck. I filled up my one storage space and still have more than half of what was in the first picture in my truck. I might put some of this on Marketplace but I have no idea of the value. I'd guess around 150 ish bdf since they estimated the load to be around 200 bdf.. I don't really even know how you calculate the bdf. I'm just a scroll sawer, Should be worth at least a couple hundred I'd think. Edited April 1, 2023 by kmmcrafts Quote
Scrappile Posted April 1, 2023 Report Posted April 1, 2023 Cherokee woods in Calif sell black walnut lumber rough cut for $11 a board foot. Length x width x thickness. 150 bf x 11 = $1650 if it is decient. kmmcrafts 1 Quote
kmmcrafts Posted April 1, 2023 Author Report Posted April 1, 2023 24 minutes ago, Scrappile said: Cherokee woods in Calif sell black walnut lumber rough cut for $11 a board foot. Length x width x thickness. 150 bf x 11 = $1650 if it is decient. No kidding? Dang I really suck then.. Now I know why you all say that. I've never bought much quantity of walnut because I knew it was pricey and most scroll projects I do doesn't look great made from walnut. I mostly use Cherry.. and I do buy it from a lumber store already edged, planed etc.. I just happen to need a piece of walnut for a special order a couple years ago and my brother hooked me up with some, then also told the other local mills I'm interested in walnut scraps.. now I'm overloaded in walnut. I put in a word about cherry.. I'm pretty sure I'll have plenty of it soon, and nowhere to put it cause I got all this walnut in my storage space, .. Surely this stuff I have is probably not considered decent because it does have areas with knots and splitting which is why it was rejected by the grade lumber buyers.. I think they require at least 6ft. long and also a certain width that is clear of knots and splits so it doesn't make the top grade. They are picky, it could be 5ft x 11.75 long and a perfect board but that 1/4" makes it a reject.. that's the kind of stuff I have here.. though some are also knots and splits.. great stuff for scroll sawing, cutting boards, and other small stuff where you can work around the bad spots. Heck some of this with the splitting is a dream for those that fill in splits etc with epoxy resin. OCtoolguy 1 Quote
MarieC Posted April 1, 2023 Report Posted April 1, 2023 I love walnut, too bad you are so far from WA state! That is a bit far for a road trip. My Mom's family is from the Upper Penninsula though...Great find! Quote
