So what you're looking at is a quote.  In this case, Gene quoted Heppnerguy.  So instead of showing the whole quote, it only shows the first part of the quote.  That way it doesn't take up so much room in the thread.  This is a problem when someone quotes someone else that may have 10 pictures in it, it takes up a whole lot of screen real estate.  We used to have this feature a few years back, but the software didn't work with the new versions.  However, we were able to update the code to make quotes a bit easier to manage.  At any rate, if you want to see the whole quote, click the Expand button and it will show you the whole quote.
I hope this helps!
