Moocifer Joe Posted April 21, 2023 Report Posted April 21, 2023 My Dewalt DW788 should be delivered tomorrow. I have never used a Dewalt SS. What are some of the things I should expect? Thanks in advance. OCtoolguy and crupiea 2 Quote
Ctutor Posted April 21, 2023 Report Posted April 21, 2023 a ton of fun!!! Oracle, Moocifer Joe and OCtoolguy 2 1 Quote
Moocifer Joe Posted April 21, 2023 Author Report Posted April 21, 2023 8 minutes ago, Ctutor said: a ton of fun!!! I hope so, looking forward to using it. OCtoolguy 1 Quote
Bill WIlson Posted April 21, 2023 Report Posted April 21, 2023 Congratulations. Is this your first scroll saw or just the first Dewalt? The Dewalt benefits greatly when combined with a couple aftermarket accessories. I would recommend connecting it to a footswitch, as Dewalts are notorious for flaky on/off switches. Dust gets inside and eventually your saw won't turn on. I had a footswitch on mine for many years and it eliminated the problem. A footswitch also makes any saw much easier to control. Also consider adding a lift mechanism. There are a couple versions available. Mine was the Jim Dandy Easy Lift Easy Lift System for DeWalt Scroll Saw DW788 – Jim Dandy Supplies. They are a very simple device that helps raise the top arm up when doing fretwork. OCtoolguy, Moocifer Joe and barb.j.enders 2 1 Quote
Moocifer Joe Posted April 21, 2023 Author Report Posted April 21, 2023 6 minutes ago, Bill WIlson said: Congratulations. Is this your first scroll saw or just the first Dewalt? The Dewalt benefits greatly when combined with a couple aftermarket accessories. I would recommend connecting it to a footswitch, as Dewalts are notorious for flaky on/off switches. Dust gets inside and eventually your saw won't turn on. I had a footswitch on mine for many years and it eliminated the problem. A footswitch also makes any saw much easier to control. Also consider adding a lift mechanism. There are a couple versions available. Mine was the Jim Dandy Easy Lift Easy Lift System for DeWalt Scroll Saw DW788 – Jim Dandy Supplies. They are a very simple device that helps raise the top arm up when doing fretwork. I started on an old Craftsman SS and up graded to a Wen LL2156. 1st Wen lasted 2 months, returned and ordered another, and it lasted 2 months, returned and ordered the Dewalt. I do use a foot switch and will be getting a lift assist. OCtoolguy 1 Quote
kmmcrafts Posted April 21, 2023 Report Posted April 21, 2023 Expect to have to install the table and adjust the angle of it to the blade.. I'd throw away that hold down foot but some people do use it. I'd also check the position of the blade in slot of the clamps. Some folks like to have it in the center of the slot and some like it over to one side or the other.. don't think it really matters so long as both upper and lower clamps are in the approximate same location. You don't really want the top one off to the right side and the bottom one to the left side basically is what I'm getting at. Do that first.. then check the blade to the table and adjust the dial indicator tab to zero it out. Getting it all tuned and dialed in first thing makes for a better overall experience and will possibly save wear on the saw if it's running smooth. If you don't have a small square you can just check the blade to table square by taking a thicker piece of scrap and cutting a notch in it a short way and then back out of the slot spin the board around to the back side of the blade and if the blade is square it should slide right into the slot you just cut.. if not then adjust and cut another slot check again and do this until you get it to easily fit. Don't know how the new DeWalts are these days but I bought my first new one back in 2008 which was a type 2 and it was an awesome saw to use.. I bought the stand with the saw and also would have to say it was the most comfortable saw to sit at that I've owed so far.. Maybe the Hegner is right up there with the 3 legged stand. Agree with Bill, I had the Jim Dandy Easy Lift system.. which made sawing a lot more pleasure. Many folks might say to just tighten the screw where the upper arm pivots.. I would not do that myself as that is eventually going to wear out that joint and deem the saw junk since I believe you'd have to change the whole saw body so basically need a new saw, LOL. I had to rebuild with new bearings in my saw after about 3-4 years of pretty heavy use. But once I did that and used a high grade synthetic grease I never did have another issue. I sold the saw back around 2018 to my sons friend. He don't saw much but still has it. Moocifer Joe, Scrappile and OCtoolguy 2 1 Quote
Jim McDonald Posted April 21, 2023 Report Posted April 21, 2023 Great saw and even though some people don't like them, I hope you got either the stock light or some type of aftermarket light. The lights make a difference seeing the black blades against the pattern. MarieC, Moocifer Joe and OCtoolguy 3 Quote
Moocifer Joe Posted April 21, 2023 Author Report Posted April 21, 2023 Yay ! My saw got delivered a day early. I went over all nuts, bolts and screws making sure all is tight. Aligned blade set screws with feeler gauge. Aligned blade in table slot. And made sure bevel adjuster was accurate. Should be back in business. meflick and OCtoolguy 2 Quote
Moocifer Joe Posted April 21, 2023 Author Report Posted April 21, 2023 52 minutes ago, Jim McDonald said: Great saw and even though some people don't like them, I hope you got either the stock light or some type of aftermarket light. The lights make a difference seeing the black blades against the pattern. Yes I have a good lighted (led) magnifier and I also wear an optiviser. I also convert all patterns to red lines. OCtoolguy 1 Quote
Gene Howe Posted April 21, 2023 Report Posted April 21, 2023 A couple magnetized sewing machine LED lights really helped. And I use a head band type flip up magnifier. Both were Amazon buys. OCtoolguy, Moocifer Joe and MarieC 3 Quote
Moocifer Joe Posted April 21, 2023 Author Report Posted April 21, 2023 1st time I moved the blower tube it cracked. No problem, I have fix for that. OCtoolguy and MarieC 2 Quote
kmmcrafts Posted April 21, 2023 Report Posted April 21, 2023 1 hour ago, Moocifer Joe said: 1st time I moved the blower tube it cracked. No problem, I have fix for that. You can take those apart and remove the broke one and put it back together, I've read there is a special tool you can use to simplify that.. I've had good luck just soaking the parts in very hot water for a few minutes to help them slide back together easier without cracking or breaking them.. Moocifer Joe and OCtoolguy 1 1 Quote
Moocifer Joe Posted April 21, 2023 Author Report Posted April 21, 2023 9 minutes ago, kmmcrafts said: You can take those apart and remove the broke one and put it back together, I've read there is a special tool you can use to simplify that.. I've had good luck just soaking the parts in very hot water for a few minutes to help them slide back together easier without cracking or breaking them.. Thanks. I warmed it up good with a hobby heat gun. All set to go now. OCtoolguy, Scrappile and kmmcrafts 3 Quote
OCtoolguy Posted April 21, 2023 Report Posted April 21, 2023 I had a used type 1 and after tuning it and doing the re-grease it was a great saw. I added the Pegas clamps and that took most all of the little vibration that it had out of it. I sanded the table top to remove the corrosion and grind marks until it was very smooth and kept it waxed. I built a 3 legged stand for it that went with it when I sold it. If I had not found a really great deal on a used Excalibur, I'd probably still have it. Moocifer Joe 1 Quote
dgman Posted April 21, 2023 Report Posted April 21, 2023 I used DeWALT saws for over twenty years. They are a good saw. No vibration and easy blade clamps. This saw was designed to top feed as well as bottom feed. Give top feeding a try. If you like top feeding,you don’t need a arm lift. I had one on my first DeWALT, but soon found it was just in the way. For easy blade changing, remove the bottom blade guard. It just gets in the way. The last thing is wax the table with any wax that does not contain silicone like car wax. Silicone can affect you finish. I use Minwax finishing wax. OCtoolguy, Moocifer Joe and Gene Howe 2 1 Quote
OCtoolguy Posted April 21, 2023 Report Posted April 21, 2023 I've been using the same can of Johnson's paste wax for about 30 years. It's really hard to use it up. Moocifer Joe, Scrappile and crupiea 3 Quote
kmmcrafts Posted April 22, 2023 Report Posted April 22, 2023 2 hours ago, OCtoolguy said: I've been using the same can of Johnson's paste wax for about 30 years. It's really hard to use it up. Me too, not quite 30 years but I bought a can back in 2007 and still using it today and I wax about 2 times a month all the surfaces of the saw tables bandsaw, tablesaw, drill press, planer, and I even do the bottom side of the dremel plunge router so it glides across the wood when I used to us it. I am getting close to being gone as the bottom of the can is bare but still around in the edges. When I found out they was discontinuing it I found a new can on eBay so I bought it. Should last me probably close to the rest of my scrolling years.. OCtoolguy and Moocifer Joe 1 1 Quote
Jim McDonald Posted April 22, 2023 Report Posted April 22, 2023 4 hours ago, OCtoolguy said: I've been using the same can of Johnson's paste wax for about 30 years. It's really hard to use it up. I thought I heard Johnson quit making their paste wax. Would be a horrible shame. OCtoolguy 1 Quote
AUTOMILE Posted April 23, 2023 Report Posted April 23, 2023 I believe Meguires yellow car wax is a good substitute for johnsons Quote
dgman Posted April 23, 2023 Report Posted April 23, 2023 55 minutes ago, AUTOMILE said: I believe Meguires yellow car wax is a good substitute for johnsons Nope! I just checked, it contains silicone. Never use any product containing silicone on any woodworking surface as it can affect your finish. Just don’t use car wax. Use a finishing wax. There are many available in the paint and finish department at any hardware store or woodworking store or catalog. Scrappile 1 Quote
kmmcrafts Posted April 23, 2023 Report Posted April 23, 2023 Just did a search on alternative waxes on google, here is what it says. What replaces Johnson's paste wax? Minwax seems to work just as well as Johnsons. Also Renaissance micro-crystaline wax. The Renaissance is a lot softer and a little goes a long way. Quote
Moocifer Joe Posted April 23, 2023 Author Report Posted April 23, 2023 Think I am really liking the DW788. Scrappile, MarieC, BadBob and 3 others 6 Quote
jerry walters Posted April 23, 2023 Report Posted April 23, 2023 WOW!! These look great Russell. Jerry Moocifer Joe 1 Quote
Jim McDonald Posted April 23, 2023 Report Posted April 23, 2023 I think you're dialed in pretty good on the new saw. Congrats Moocifer Joe 1 Quote
