It seems when I get really close to something that is delicate, I blink.  So it happened once again, and then I am down on my hands and knees in the sawdust looking for my leaf, which I luckily found.  So CA glue to the rescue, but it is so tiny I have to use a tweezer and when I pick it up it pops out of the tweezer and flys across the room!  I luckily find it again, but this time I didn't use a tweezer and the leaf gets stuck to my finger!  Arrgh!  Does this happen to anyone else or just me?  Does it get less frequent (blinking) as you get better?  Any tips?  I will hopefully show you my trees soon and hope that they won't be snags by the time I get them done!🤣  Thanks for your suggestions ahead of time...mariec
Edited by MarieC
It happens to me and usually goes underneath something.
I used to lose small pieces while using my sanding mop. Two things helped that a lot. A tall fence on the back of the drill press stops 98% of them, and a net over the end of my dust collection to keep them from entering the shop vac.
Blinking?  I never thought much about it.  Although, now that you have brought it to my attention, I'm sure it will find a place in my consciousness.  So thanks for that.  🤨 😛
As for dropping tiny bits on the floor, that happens all too often.  The only difference is that I rarely find what I dropped.  There must be some metaphysical connection with the clothes dryer and all of these lost bits & pieces have joined with the missing socks, in some Bermuda triangle like alternate existence.
Awww, the net over the dust collection system....what a great idea...I have lost a many things to my dust collection system....Thanks for that tip!
After reading all these miss-haps, I am so glad I am not alone....I have never laughed so hard in a long time... some of which brought tears to my eyes 🤣...thanks for sharing your crazy stories!
Edited by MarieC
As I was reading your story I was thinking "her luck is almost as bad as mine." My brother could take dog droppings and make money from it whereas I would most likely trip and fall into it face first. The old saying, "If it wasn't for bad luck, I wouldn't have any luck at all," definitely applies to me. Does it get better? If it does for you, please let me know. It would give me something to look forward to.
At my age, whenever a small item falls to the floor, I have a series of qualifying decisions to make. Do I really need it? Do I have more in the box? Can I see it on the floor? Is it easily accessible? Is it ferrous? If so, where did I use the magnet last? If I've answered all those questions satisfactorily and the magnet retrieval doo-hicky isn't found or not applicable, it's time to get down on the floor. Which brings about another set of questions. Is the object in such a spot that my huge girth can fit in order to grab the wayward, lost object.  Can I use a bench or tool to help me get up. Preferably, something not on wheels and not easily tippable. If all the conditions are right and I'm down on hands and knees or, more likely, on my butt, there one final question..."Now, Is there anything else I can do while I'm down here?"
  • 1 month later...
On my Excalibur saws, the sawdust that doesn't get caught up by the dust control will filter down onto my lap or shoes. So, I made a couple of slide in/slide out boxes and they catch what dust makes it through. That's where all the tiny pieces also go if they don't get sucked up. So far I've had good luck with finding them. If they do get sucked up, well, that's called "creative license".
Ray, if you get a minute, could you take a picture of your slide in/out boxes...are they on the floor or just under the saw table?
Just under the frame of the saw so that all the dust just drops down into them. 3 Sided with a bottom. 1/8" BB ply.
Edited by OCtoolguy
  • 3 weeks later...
I found that a cardboard box with an open side and a piece of foam taped to the back of the box can catch the pieces the mop insists of grabbing and trying to throw across the room when sanding the edges on the drill press.  When I get the saw and drill press set up again, I'll take a picture or two so you can see what I mean.
I use my mop on a large drill press. Having a tall fence on the back will also help with this. Before I had the fence the sanding mop would always throw the pieces behind or under something.
