Dave Monk Posted May 14, 2023 Report Posted May 14, 2023 https://www.etsy.com/listing/1221023515/chess-board-game-wall-decor-wooden-chess?click_key=ed5a03b95ee187a06e91bf2d6ada976717a9d447%3A1221023515&click_sum=f0c4e34a&ref=shop_home_active_79&pro=1&frs=1&sts=1 Do you think the squares are glued to metal? What type of magnet do you think you would use? OCtoolguy 1 Quote
rafairchild2 Posted May 14, 2023 Report Posted May 14, 2023 (edited) 10 minutes ago, Dave Monk said: https://www.etsy.com/listing/1221023515/chess-board-game-wall-decor-wooden-chess?click_key=ed5a03b95ee187a06e91bf2d6ada976717a9d447%3A1221023515&click_sum=f0c4e34a&ref=shop_home_active_79&pro=1&frs=1&sts=1 Do you think the squares are glued to metal? What type of magnet do you think you would use? From the description, it says he has "magnets behind." I would drill a small hole deep enough to take the small magnet, but not deep enough to drill through the square. Of course, you would do the same thing with the playing piece, just have the opposite polarity. It would be a lot of drilling nearly 100 holes! The seller (Serhan) is from Turkey. I forgot if it was Istanbul or Ankara. Nice guy, his scroll saw plans are great and priced very reasonably too. This is what I use for magnets on my projects. I get a pack of 60 Mini Magnets for $6. https://amzn.to/3O7Zekd Edited May 14, 2023 by rafairchild2 Dave Monk and OCtoolguy 1 1 Quote
flarud Posted May 14, 2023 Report Posted May 14, 2023 That's pretty neat! Here is another that has shelves across the board. https://www.etsy.com/listing/952352918/black-walnut-board-with-traditional?click_key=936256b7762f1e840f37e8a3464244397d45fc1e%3A952352918&click_sum=877462d9&elp_to_elp_for_all_recs=1&ref=landingpage_similar_listing_bot-2&sts=1&listing_id=952352918&listing_slug=black-walnut-board-with-traditional OCtoolguy 1 Quote
Dave Monk Posted May 14, 2023 Author Report Posted May 14, 2023 10 hours ago, flarud said: That's pretty neat! Here is another that has shelves across the board. https://www.etsy.com/listing/952352918/black-walnut-board-with-traditional?click_key=936256b7762f1e840f37e8a3464244397d45fc1e%3A952352918&click_sum=877462d9&elp_to_elp_for_all_recs=1&ref=landingpage_similar_listing_bot-2&sts=1&listing_id=952352918&listing_slug=black-walnut-board-with-traditional I've seen the ones with shelves but I like the idea of magnets better. Thanks for sharing. OCtoolguy 1 Quote
Dan Posted May 14, 2023 Report Posted May 14, 2023 I've made dishwasher signs, Clean on one side Dirty on the other. I drilled 1/4" holes in 1/4" ply to embed the magnets. Then glued 1/16" ply on both sides. Works great, hides the magnets and doesn't scratch the dishwasher. Dave Monk, OCtoolguy and MarieC 3 Quote
ChelCass Posted May 14, 2023 Report Posted May 14, 2023 11 hours ago, Dave Monk said: https://www.etsy.com/listing/1221023515/chess-board-game-wall-decor-wooden-chess?click_key=ed5a03b95ee187a06e91bf2d6ada976717a9d447%3A1221023515&click_sum=f0c4e34a&ref=shop_home_active_79&pro=1&frs=1&sts=1 Do you think the squares are glued to metal? What type of magnet do you think you would use? Dave I think it is all one piece with the squares painted on. You can go with the mini magnets or you can buy sheets of magnets and cut to any shape you like. OCtoolguy and Dave Monk 2 Quote
barb.j.enders Posted May 14, 2023 Report Posted May 14, 2023 There is also paint available that will turn any surface into a magnetic board. It is a primer so you can paint over top. MarieC, crupiea, OCtoolguy and 1 other 3 1 Quote
rjweb Posted May 14, 2023 Report Posted May 14, 2023 Dave, I see a new project in your works, looking forward to see your version, RJ Scrappile, OCtoolguy and Dave Monk 3 Quote
crupiea Posted May 14, 2023 Report Posted May 14, 2023 What if you just used a thin veneer on top of a metal sheet? Not sure it would work but a thought. Dave Monk, OCtoolguy and MarieC 3 Quote
MarieC Posted May 15, 2023 Report Posted May 15, 2023 Dave, well if you make it, be sure and Post it in the Bragging section so we can see it. I am sure you will do a fantastic job! OCtoolguy and Dave Monk 2 Quote
