Did you buy the ones made for Dewalt? I bought the ones made for Excalibur & Jet so I could set the tension with the slider and then just flip the lever for applying/loosening the tension. Worked great.
I just asked Denny for the Pegus clamps for the 788.
Ray, what do you mean by "set the tension with the slider"?   I also flip the lever for applying and loosening but not sure what the slider is?  Thanks, mc
On Dewalt saws you adjust the tension with a lever. Correct? That lever does the same job as the knob at the back of Ex type saws. It sets the amount of tension. The flip lever on the Ex saws/clamps actually " locks" the tension that has been set by the lever/knob. Its faster as far as I'm concerned. I hope you understand what I'm saying. Once your tension is set, you don't have to adjust it again until you change blades.
Okay, I get what you are saying now and Yes, that does make sense to me, Thanks   :)
What am I missing? I never change tension unless I'm changing blades.
I do release tension after a session. My sessions are short. Saw a bit, do something else and, come back.
Ok, tell me how you apply tension. Is it not by sliding/turning the tension ring? On my saw, I'd set that amount of tension and leave it there. Don't touch it again. Then I would apply/release that set tension by simply flipping the little lever.
Aha. My DW 788 just has the tension ring thingie. No levers.
Correct. The lever is on the Pegas clamps. But not the ones sold for Dewalt. It was something that I experimented with and it worked. They are a more expensive set but worth it. When I sold my Dewalt I just moved them over to the Ex that I acquired. I now have two Ex factory clamp sets that would probably work on Dewalt/Delta saws that would be better than stock ones.
Edited by OCtoolguy
