James E. Welch Posted June 26, 2023 Report Posted June 26, 2023 What glue do you guys use? I'm wondering specifically what glue you use on painted/stained backer boards. Wood glue wouldn't stick to paint well right? Does CA glue hold up well long term?? OCtoolguy 1 Quote
preprius Posted June 26, 2023 Report Posted June 26, 2023 (edited) non painted wood for indoors: titebond 2 non painted wood outdoors: titebond3 painted/finished wood or smooth metal surfaces: baking soda and CA glue. I will try pencil lead powder and baking soda w/CA glueb if I want a dark looking joint. cement or porous surfaces: E6000 or E6800 2 Part epoxy is another glue I have at the ready. Edited June 26, 2023 by preprius OCtoolguy and James E. Welch 1 1 Quote
kmmcrafts Posted June 26, 2023 Report Posted June 26, 2023 I asked this a few years back and Weld Bond was what I was directed to at that time.. I used it a few times and so far seems to be doing the job fine. It was just light work to hold a painted backer to a cutting that hangs on the wall so there isn't much if any stress to the pieces I did with the Weld Bond. OCtoolguy 1 Quote
OCtoolguy Posted June 26, 2023 Report Posted June 26, 2023 6 hours ago, kmmcrafts said: I asked this a few years back and Weld Bond was what I was directed to at that time.. I used it a few times and so far seems to be doing the job fine. It was just light work to hold a painted backer to a cutting that hangs on the wall so there isn't much if any stress to the pieces I did with the Weld Bond. It dries clear too. kmmcrafts and crupiea 2 Quote
Roberta Moreton Posted June 26, 2023 Report Posted June 26, 2023 I use Aleene’s Turbo Tacky Glue. I haven’t had a problem. OCtoolguy, jollyred and danny 3 Quote
crupiea Posted June 27, 2023 Report Posted June 27, 2023 2 hours ago, Roberta Moreton said: I use Aleene’s Turbo Tacky Glue. I haven’t had a problem. I use this if its going to sort of ooze out and you can see it. Like fretwork on a backer. Never had an issue with it. otherwise I use wood glue. danny 1 Quote
James E. Welch Posted June 27, 2023 Author Report Posted June 27, 2023 6 hours ago, crupiea said: I use this if its going to sort of ooze out and you can see it. Like fretwork on a backer. Never had an issue with it. otherwise I use wood glue. You use wood glue on painted surfaces? Does that work well? Quote
James E. Welch Posted June 27, 2023 Author Report Posted June 27, 2023 6 hours ago, clocks and more said: Gorela white glue. This works good on painted or stained surfaces? Quote
Dave Monk Posted June 27, 2023 Report Posted June 27, 2023 I use tacky glue or 3M77 spray glue. Quote
Paladin Posted June 27, 2023 Report Posted June 27, 2023 My vote is for Aileen's tacky glue as well. Any painted backers this is what I've used for years and never had any problems. James E. Welch and danny 2 Quote
OCtoolguy Posted June 27, 2023 Report Posted June 27, 2023 17 hours ago, Roberta Moreton said: I use Aleene’s Turbo Tacky Glue. I haven’t had a problem. I used to mow her lawn in Arcadia Ca. It was a huge lawn. $30/mo. Jim McDonald and MarieC 2 Quote
Gene Howe Posted June 27, 2023 Report Posted June 27, 2023 21 minutes ago, OCtoolguy said: I used to mow her lawn in Arcadia Ca. It was a huge lawn. $30/mo. You didn't stick with it? How tacky. James E. Welch, dgman, ChelCass and 5 others 1 7 Quote
James E. Welch Posted June 27, 2023 Author Report Posted June 27, 2023 4 minutes ago, Gene Howe said: You didn't stick with it? How tacky. Gene Howe, kmmcrafts, OCtoolguy and 1 other 4 Quote
Davevand Posted June 27, 2023 Report Posted June 27, 2023 I started using this a while ago and really like it, tacks up fast and really holds TITEBOND QUICK & THICK MULTI-SURFACE GLUE James E. Welch and OCtoolguy 2 Quote
OCtoolguy Posted June 27, 2023 Report Posted June 27, 2023 1 hour ago, Gene Howe said: You didn't stick with it? How tacky. She died. My buddy, who was my partner in the mowing business, got into a fight with her husband. Knocked him out. So, that ended that job. MarieC, Gene Howe and James E. Welch 3 Quote
Scrappile Posted June 27, 2023 Report Posted June 27, 2023 Many times I have sprayed the back of the picture with spray adhesive 77 and put the backer on. Never had a problem. MarieC and OCtoolguy 2 Quote
Roberta Moreton Posted June 28, 2023 Report Posted June 28, 2023 On 6/27/2023 at 4:40 AM, James E. Welch said: You use wood glue on painted surfaces? Does that work well? Aleene’s Turbo Tacky glue is a craft glue. James E. Welch 1 Quote
James E. Welch Posted June 28, 2023 Author Report Posted June 28, 2023 2 minutes ago, Roberta Moreton said: Aleene’s Turbo Tacky glue is a craft glue. I'm going to have to get some of this stuff. It's been highly recommended. Quote
Roberta Moreton Posted June 28, 2023 Report Posted June 28, 2023 2 minutes ago, James E. Welch said: I'm going to have to get some of this stuff. It's been highly recommended. You can get in in a craft store like Michael’s or Hobby Lobby or the craft department at Walmart. James E. Welch 1 Quote
crupiea Posted June 28, 2023 Report Posted June 28, 2023 I have used wood glue on painted surfaces with no issues. I clamp it down for at least a day. James E. Welch 1 Quote
James E. Welch Posted June 28, 2023 Author Report Posted June 28, 2023 8 minutes ago, crupiea said: I have used wood glue on painted surfaces with no issues. I clamp it down for at least a day. I'm going to have to do some experimenting with this. I've never actually tried it, I just thought it wouldn't work well (I'm not sure where I got that thought from). Quote
Jim McDonald Posted June 28, 2023 Report Posted June 28, 2023 I just yesterday started a round of wood to wood and wood to metal projects with E6000. Seems to a great job, but is a lot like some of the tube style glues from the past--it can be runny. (I'm looking at you, ghost of DuPont Duro). ChelCass and James E. Welch 1 1 Quote
James E. Welch Posted June 28, 2023 Author Report Posted June 28, 2023 2 minutes ago, Jim McDonald said: I just yesterday started a round of wood to wood and wood to metal projects with E6000. Seems to a great job, but is a lot like some of the tube style glues from the past--it can be runny. (I'm looking at you, ghost of DuPont Duro). (I'm looking at you, ghost of DuPont Duro).--- I laughed way too hard at this. LOL Quote
ChelCass Posted June 28, 2023 Report Posted June 28, 2023 I use E6000 all the time. A little goes a long way. I have glued wood to wood (painted), glass to glass, metal to wood and glass to wood with no problems. If I am doing a really small piece then I use a toothpick to apply the glue. Can be bought at walmart, and any craft store. MarieC and James E. Welch 2 Quote
