Oldmansbike Posted June 26, 2023 Report Posted June 26, 2023 I am making this clock and I’m having trouble cutting the small pieces to size before I cut the scroll work. I have been using my miter saw but I’m afraid I’m going to lose a finger doing it with the miter saw. How do you guys cut really small pieces? I’m talking an inch wide by two inches long and some are smaller than that. Thanks OCtoolguy 1 Quote
OCtoolguy Posted June 26, 2023 Report Posted June 26, 2023 2 minutes ago, Oldmansbike said: I am making this clock and I’m having trouble cutting the small pieces to size before I cut the scroll work. I have been using my miter saw but I’m afraid I’m going to lose a finger doing it with the miter saw. How do you guys cut really small pieces? I’m talking an inch wide by two inches long and some are smaller than that. Thanks Sometimes, since I have to set up my table saw each time, I opt for a quick cut on my bandsaw or just rough it out on the scroll saw. I guess it depends on what it is. The other day, I wanted a small piece of walnut that I had a 1x 2 of. Rather than get out my table saw, I just took it to the bandsaw. I agree with you on using the miter saw for tiny things. Dangerous. danny 1 Quote
Oldmansbike Posted June 26, 2023 Author Report Posted June 26, 2023 Thanks for the reply Ray. I thought about the bandsaw but didn’t know if I could get them cut square. I guess I’ll try it because I have a lot more to cut to finish the clock. OCtoolguy 1 Quote
James E. Welch Posted June 26, 2023 Report Posted June 26, 2023 Even the Tablesaw could be dangerous when cutting small pieces if not careful, but you're right the miter saw is not a great option for small pieces. I'd go with the bandsaw or Scrollsaw with a bigger blade. I keep an old cheap pin style Scrollsaw for this kind of thing or use my bandsaw. Sometimes I'll use the Tablesaw but usually with a sled OCtoolguy and danny 2 Quote
Dan Posted June 26, 2023 Report Posted June 26, 2023 (edited) Rockler makes a small parts jig for the table saw. It worked pretty good for me. It's basically a small sled and is pretty safe. I still have all 11 fingers. Wait, no, just 10. Edited June 26, 2023 by Dan danny, James E. Welch and OCtoolguy 1 2 Quote
Tom-in-Ashland Posted June 27, 2023 Report Posted June 27, 2023 What about something like this. https://www.homedepot.com/p/MicroLux-Mini-Tilt-Arbor-Table-Saw-for-Benchtop-Hobby-Use-80463/312434052?source=shoppingads&locale=en-US&&mtc=SHOPPING-BF-CDP-GGL-D25T-025_009_PORT_POWER-NA-Multi-NA-SMART-NA-NA-NA-NA-NBR-NA-NA-NA-PortPower&cm_mmc=SHOPPING-BF-CDP-GGL-D25T-025_009_PORT_POWER-NA-Multi-NA-SMART-NA-NA-NA-NA-NBR-NA-NA-NA-PortPower-71700000106625794-58700008274559054-92700076261262900&gclid=Cj0KCQjw7uSkBhDGARIsAMCZNJtJh4oNmZBAOBf4xbzNPsgQ6bVuwHkXx_9cLuxPE0H4U42IC_r_mfUaArx1EALw_wcB&gclsrc=aw.ds or. https://www.micromark.com/MicroLux-Mini-Tilt-Arbor-Table-Saw-for-Benchtop-Hobby-Use_2?gclid=Cj0KCQjw7uSkBhDGARIsAMCZNJsy4T2kV-oTNtqbFFeGY215lfIZauJEp-S6Zu3uMIDW6jG9HgiSVNIaAnLnEALw_wcB OCtoolguy 1 Quote
CharleyL Posted June 27, 2023 Report Posted June 27, 2023 (edited) I use one of these to hold the piece while cutting it on my table saw, band saw, or router table, or even a scroll saw, but I added strips of sticky backed 80 grit sandpaper to the surfaces that grip the part for a better and safer grip. Actually, this isn't exactly the one that I have. Mine is yellow and has an aluminum guard along one side that can be angled to ride against a fence. I can cut very small pieces with this, without putting my fingers in harms way. https://www.amazon.com/Holder-Router-Tables-Safely-Smaller/dp/B06ZYNNFVW/ref=sr_1_42?crid=1KYUUUBKM7X9Q&keywords=small+part+cutting+jig&qid=1687835367&sprefix=small+part+cutting+jig%2Caps%2C110&sr=8-42 Sorry, I can't remember where I bought the yellow one, but if it comes to me I'll update this post. I think the yellow one is the original, but now even Rockler is making one, but of course it's Blue and more expensive. Found It !! - This is the one that I have. https://www.infinitytools.com/router-table-saw-small-workpiece-holder Charley Edited June 27, 2023 by CharleyL OCtoolguy and JessL 1 1 Quote
BadBob Posted June 27, 2023 Report Posted June 27, 2023 I routinely cut small pieces on a 12-inch miter saw. If you clamp it correctly, it isn't difficult or dangerous. If you want to know how, watch this. JessL and OCtoolguy 1 1 Quote
Oldmansbike Posted June 27, 2023 Author Report Posted June 27, 2023 1 hour ago, BadBob said: I routinely cut small pieces on a 12-inch miter saw. If you clamp it correctly, it isn't difficult or dangerous. If you want to know how, watch this. Thanks Bob I think that’s what I need to try BadBob and OCtoolguy 2 Quote
CharleyL Posted June 30, 2023 Report Posted June 30, 2023 This is what I use. Having one near the miter saw, table saw, scroll saw, etc. and getting comfortable with it will save you from a lot of accidents and near misses. Charley https://www.amazon.com/FastCap-10-Million-Dollar-Stick/dp/B0728GYJ5G/ref=sr_1_1?crid=25MK5SP54JZP1&keywords=10+million+dollar+stick+for+miter+saw&qid=1688086100&sprefix=10+million+dollar+stick%2Caps%2C115&sr=8-1 OCtoolguy and danny 1 1 Quote
Roberta Moreton Posted July 4, 2023 Report Posted July 4, 2023 Never raise the blade while it is spinning! danny and OCtoolguy 1 1 Quote
