AlRosenberger Posted July 21, 2023 Report Posted July 21, 2023 I have a smaller cheap scroll saw, Wen 16 inch(?), can I cut a pattern that is 10x13? I know could cut it with a spiral blade, but being new to scrolling I have never used a spiral blade and am half afraid to try. So, the basic question is can I cut this pattern on my saw with flat blades. OCtoolguy 1 Quote
TAIrving Posted July 21, 2023 Report Posted July 21, 2023 Al, welcome to the SSV forum. You should be able to cut that pattern on your scroll saw, but it does depend on the size of the blank you are cutting. The 16" dimension is the distance between the blade and the rear of the scroll saw arm - measure it for yourself. Then, after you mount the pattern on the blank, measure the distance from any point on the pattern to the farthest corner of the blank. That is the corner that would hit the arm support when you are cutting that far part of the pattern. So, you might have a problem if you mount a small (less than 16") pattern to a too-large wood blank. Post pictures when you complete your project. We all are impatient to see! OCtoolguy and danny 1 1 Quote
AlRosenberger Posted July 21, 2023 Author Report Posted July 21, 2023 Thanks, I will measure right now. I will send pictures. I am slow so it might be a while. OCtoolguy 1 Quote
Dak0ta52 Posted July 21, 2023 Report Posted July 21, 2023 I started with a WEN 16-inch and have cut many 11X14 pieces. You may have to use a spiral if you're cutting along an edge in a corner. Don't let spirals scare you. They are much easier than you think. Just remember to GO SLOW until you get use to them. I've also noticed the spirals have a tendency to "bow" as you push your work into the blade. The thicker the work piece, the more the bow. This is another reason to go slow. When you get to a corner or sharp turn, stop pushing into the blade and allow the blade to "catch up" before making your turn. For the most part, you should be able to cut most pieces with a straight blade unless the piece is heavily fretted in the corners. Fortunately, my new Pegas cured any concerns with this issue, especially with a 30-inch throat. Good luck with your cut. danny and OCtoolguy 2 Quote
AlRosenberger Posted July 21, 2023 Author Report Posted July 21, 2023 Thanks a lot. Itis appreciated. I am going to have lose my fear of spiral blades. OCtoolguy and danny 2 Quote
OCtoolguy Posted July 22, 2023 Report Posted July 22, 2023 3 hours ago, AlRosenberger said: Thanks a lot. Itis appreciated. I am going to have lose my fear of spiral blades. I've been scrolling for 8 years or so and still haven't found a need to try them. Probably won't either. danny 1 Quote
don in brooklin on Posted July 22, 2023 Report Posted July 22, 2023 For over sized patterns her is a video. the trick is to drill extra holes and to tape the back. https://youtu.be/qO00Z7hatK4 BadBob, AlRosenberger, OCtoolguy and 2 others 2 3 Quote
AlRosenberger Posted July 22, 2023 Author Report Posted July 22, 2023 Thanks, I am going to try that solution. Quote
