Is the dremel plunge router a good tool?  I am going to need to cut grooves 1/16 inches wide an 1/16 inches deep. The cuts are too small for a big router. Or does anyone have a better idea of cutting these grooves?  Longest one will be 2” a shortest 1/4” long.
Got a pattern from toys and joys for making a VW bus. Need to cut groves to highlight doors and engine vents. Like I said to small for trying to use a big router. And the groves don’t go from one end to the other so using a thin table saw blade is out.
Here is the best you can get for what you want, in my opinion.   I have this one: https://www.stewmac.com/luthier-tools-and-supplies/types-of-tools/routers-and-bits/routers/precision-router-base/ it is smaller than dremels, I think.  I also have the parts to make it a plunge base if I want.  Simple conversion.  Or you can go all out and get this one:  https://www.stewmac.com/luthier-tools-and-supplies/types-of-tools/routers-and-bits/routers/stewmac-plunge-router-base/.   It's own light where you need it and a blower to blow the dust away.  Nice deal on it right now two bases for the price of one.  If I were going to be making a lot of models I would get their plunge.  I could see all kinds of uses for it in model making.  I bought mine for making cigar box guitars. I use it a lot.
I am 50/50 with the Dremel plunge router. Practice on some scrap until you feel comfortable or feel like giving up. If you have a good guide and good grip you should do good.
I have a Dewalt 1.25HP compact router.  It's a bit bigger than a Dremel, but far smaller than full size routers.  I got a plunge base for it last Christmas.  It has a standard 1/4" collet, so it doesn't need special bits.  It's great for small, hand held type work.
I've been using mine only for drilling pilot holes and have found that it is sloppy enough that it bends the bits. I've tried to figure out a way to tighten it up but so far I haven't had any luck. But, now that I have the Stewmac I will probably put the Dremel up on the shelf.
