Hi All
This is Barbara
I have a follow up question about cutting bowls and have decided I am aiming to do one.  I want to know if Steve says he cut it with a certain width of wood
does it change if you use a different width.  I mean how you cut or deel with it.  I want to try it with a peace of pallet wood I have it is to learn different woods
and get a different skill.  He has lately done a bowl or I might try one of his older patterns.
Thank you
If it is Steve's pattern does not matter.  If Barbra's then it does since you cut hers at an angle to begin with.  Steve's and Alexas are stacked one upon the other.  the size in the diameter gives the illusion of an angle.  But Barbras start with an angle cut and then are sanded on that angle to give a flat profile all the way up.
