Popular Post Wichman Posted October 17, 2023 Popular Post Report Posted October 17, 2023 Three more football plaques done. Team colors for each. Steve Good pattern to start, I replaced the text added the shaker pegs and the countersunk holes under the stripes The piece is 2, 1/2" BB laminated together after the interior cuts in the top, exterior cuts made after lamination ( 1" thick ), interior cuts made with FD Polar #1, exterior cuts made with FD polar #5. Lamination with polyurethane glue applied with a 4" foam roller then weighted down by a cinder block. 3 1/2" shaker pegs. wombatie, Loskoppie, jollyred and 10 others 12 1 Quote
FrankEV Posted October 17, 2023 Report Posted October 17, 2023 Well done. Taking nothing away from your work, however, when you use all CAPS of a somewhat Script Font it can be a little hard to read. I think if you had used both upper and lower case letters the names would have read better, or, a more simple block style font may have worked better if they needed to be all caps.. New Guy 1 Quote
heppnerguy Posted October 18, 2023 Report Posted October 18, 2023 Sports fan love these and with the personal names on them makes them even more desirable. Nice work Dick heppnerguy Wichman 1 Quote
Wichman Posted October 18, 2023 Author Report Posted October 18, 2023 19 hours ago, FrankEV said: Well done. Taking nothing away from your work, however, when you use all CAPS of a somewhat Script Font it can be a little hard to read. I think if you had used both upper and lower case letters the names would have read better, or, a more simple block style font may have worked better if they needed to be all caps.. That font, mathjax calligraphy, only has uppercase letters. That's the font the customer saw and liked so that's what I used. My current favorite font is Z003 and is much more readable and has both upper and lower case letters. Painting the inside of the letters was a royal pain, I ended up thinning the craft paint (gloss white) 50/50 with water, then dripped the paint into the recesses with the small hole in the cap, once the letter was full I used a small wire (ornament hanger) to stir the paint around in the hole and get better coverage/adhesion of the paint. FrankEV 1 Quote
